Heater blower wanted...oops
bugedd
This week I decided to restore all the heater parts on the bugeye. The heater box went to get powder coated, the bits and pieces have been on the wire wheel getting prepped for paint, and the blower motor was on the workbench as I figured out the best plan of attack to make it look good. Four or five hours later I was in the house and heard something crash in the garage. I walked out and there was the blower, in 20 or so pieces all over the floor. I have no idea how it fell off the bench, there was no one around. I'm blaming it on a ghost. But not I am in need of a blower housing at least, as my motor works fine. Any donors out there??
Rut
Try eBay, Matthews auto parts in Birmingham, AL, British Masters, etc if you don't find one here. How quick do you need it? Time is your friend on this one.
Rut
bugedd
bugedd
I did see the Ashley Hinton, will most likely go that route. I want to get it done sooner than later. I've been driving the car a fair amount, but with no top and 50 degrees, I'll take the heater, even if it only works so-so. I'm still baffled on how it fell off the work bench.
Jim_Gruber
Earthquake. You are in California. Things move on their own.
Billm
When I got my Midget someone had dropped a battery on it and broken it pretty badly- I found that common 5-minute epoxy works on it pretty well and it is still working years later.
BillM
bugedd
bugedd
Mine was that repairable at first, it had 3 or 4 cracks. Now its in many tiny pieces. I ended up ordering one from Ashley Hinton. Its not original, but its the easy route.
bugedd
bugedd
Thanks, I actually ordered one from you, couldn't believe how fast you got it to me!
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
Joe Schlosser Bugeye combo Heater blower Switch Spridgets 4
steveg Heater Blower voltage drop Austin Healey 8
N Replacing Heater Blower Austin Healey 7
maxwedge5281 heater blower ducting Austin Healey 6
D TR6 76 TR6 Heater/Blower Switch Triumph 1
R Heater Blower Motor Austin Healey 9
P POLISHING HEATER BLOWER HOUSING Spridgets 7
I Shop to check heater blower motor in Washington? Triumph 6
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
S Heater Blower Installation Austin Healey 5
jvandyke heater blower wiring Spridgets 2
I bugeye heater blower attachmetn help Spridgets 9
Woodie heater blower, demister/defroster Spridgets 8
AUSMHLY Fresh air hose clamp, heater blower ground Austin Healey 5
zimmy TRADE?-heater blower Spridgets 3
Brosky Heater blower blowing fuses Triumph 6
T MGB 1980 MGB heater blower motor MG 1
T MGB Heater blower motor for 1980 MGB MG 2
P TR6 72 tr6 heater blower Triumph 2
M AC/Heater Blower Problem Jaguar 2
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
