Steering box lubricant
vette
Penrite Steering Box Lube. I inject it in with a large cooking syringe.
steveg
Plenty of previous discussion on this topic. Search for "NLGI 0" or "penrite" or "corn head",
Expensive, hard-to-get Penrite is rated NLGI 00. Search on Amazon for "00 grease" and you'll find alternatives under $20 in quart bottles with squirt tops. In my experience one bottle of Penrite is not quite enough to fill the box.
I'm using John Deere Corn Head grease (next grade stiffer NLGI 0) which is easy to input with a grease gun with injector - if you have those things. It has the consistency of mustard so is less likely to leak, but has the disadvantage of not being drainable. The injector makes it easy to fill the box from the bottom, pushing the air out the opening.
Whatever you use, make sure you operate the steering lock-to-lock a few times during the process or the box won't be completely filled.
Almost anything should be good for the worm gears, and maybe the bearings, but how does a super-thick grease get down through the bronze bush, the biggest wear point in a box? I almost don't mind a little oozing out the bottom since it means the bush and lower rocker are getting lubricated.
blue62
In the process of restoring a 1960 BT7 I have read many threads on this subject.
Just installed the steering box yesterday. So I am wondering where does the steering box most usually leak from?
The end cover gasket? the olive? the top cover gasket? the seal?
I rebuilt the steering box then filled it with 90W GL4 as per the shop manual.
I let it set for a week and no leaks so i installed it.
as I was finishing up it occured to me that the box sits buy the radiator.
Perhaps heat from the radiator causes the fluid to expand and it gets forced out of the box.
thoughts?
In my experience, the most common point for leaking is the bottom seal, as it's at a wear point. If the bush is worn the rocker shaft will wiggle and that accelerates the wear. The end cover can leak as well, although properly set up it shouldn't; same with the compression fitting (olive). The top cover won't leak, unless it's warped, with a good gasket and, if you like, your favorite gasket sealant (Permatex Aviation Form-A-Gasket seems to be the choice of the pros).
If you fill to the bottom of the filler hole, you still have plenty of room for heat expansion: there is no seal so the oil can expand up the steering shaft tube. Confession: I was filling a dry box once with the front-end elevated and put almost a quart into it before I realized I was filling up the steering tube.
steveg
Bob, what super-thick grease are you referring to?
Penrite is like honey; Corn Head is like mustard or applesauce.
steveg
andrea
Hard to find One That NO Leaks- BUT filling all around the steering BOX-and don't go to solid state in winter
PENRITE can be the right compromise- Gear oil 90W and grease MIXTURE??MAIONESE??
RAC68
Bob,
When considering the use of Corn Head Grease, consider the purpose for which it is being selected. If the steering box is not leaking, the use of the originally specified Gear Oil (90w@ above 10F/80W@ below 10F) should be considered. Keep in mind that John Deere Corn Head Grease was formulated to service slow speed high pressure gear cases (as our steering box) at temperatures ranging from -30F to 330F. Although this is an NLGI 0 rated grease, its very soft with a consistency of Brown Mustard (as Steve indicated) and this structural difference from straight gear oil is the reason for it eliminating leakage. Although different in structure to gear oil, I have been told that it is fluid enough to fill all voids in the box and allow full penetration during slow gear movements.
Your choice, however, in steering box lubricantion and that of all other Healey components, today's selection is on a best guess effort. Even gear oil has changed in formulation and structure from that which was originally evaluated for specification in the manual.
Just my thoughts,
Ray(64BJ8P1)
I've got almost 200K miles on my BJ8's box using gear oil (85W-90 or whatever's handy); I'm not convinced that something with the consistency of mustard--see photo--can get through the small channels in the bushing to lube the bushing and rocker shaft. Glad it works for some people; the minimal miles most people drive their Healeys probably makes it a non-issue.
Luegolover
Slight twist to the topic here, hope you don't mind. I am rebuilding a BN1 and have bought Penrite for the box which I am about to install into the inner bodywork. What I would like to know is this: Do I have to have the stator tube installed before I fill the box with Penrite? I fear the answer is obvious but I wanted to check as if I have to have the stator tube in then I need to have the steering wheel permanently fitted and I don't want to do that yet. Additionally should I use Penrite on the idler as well?
RTaillieu
I think a lot of people have a misunderstanding of how Corn Head grease works. It thins out to a thick oil consistency when the unit it is in is working whether it is a corn head gearbox or a steering box.
When it's not being worked it thickens back up. Here is a link to a John Deere video that explains how it works.
https://www.youtube.com/watch?v=7zNhli-J0Gk
I just bought some to put in my steering idler once I'm finished rebuilding it.
Cheers
Rick
'64 BJ8 P1
Stinger TR4/4A TR4A Steering Box Lubricant Triumph 6
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
Martinld123 Steering Box Leak Austin Healey 27
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Walter74 Steering Box End Play Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box fluid again.... Triumph 2
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
B Steering box BJ8 Austin Healey 5
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
B Outer steering column connection to the steering box Austin Healey 6
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
M BN1 "in-site" steering box overhaul ? Austin Healey 4
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
K TR2/3/3A Steering Box Triumph 2
M BJ8 Steering box removal Austin Healey 8
T Steering Box Pinion Seal [?] Spridgets 1
