TR2/3/3A Body Mounting Bolts.
Skellyt
Hello Forum. Is anybody aware of whether there are any torque specs. for body mounting bolts on my TR3B. I have checked the workshop manual (reprint), my Haynes manual and searched the forum, but could not find any. Since I couldn’t find any, my thoughts were to tighten them as tightly as possible after adding some lock tire to the threads.
Thanks, Tom
sp53
You probably will not find a number; the bolt is not a steel to steel attachment because the bolt goes through the rubber shims. I would tighten the bolt until the lock washer closes and perhaps a few pounds more and not so tight as to rip the thin rubber pad. With the lock washer closed, the vibration of driving is less apt to loosen the bolt. However, others might have a different view.
Madflyer
My TR 6 book states what should be the same for your TR 3 10 to 14 Lbs 3/8 fine thread. As they may have any number of shims and rubber to fit doors ect. it just holds body true. NOTE fine thread bolts strip easy at any location. here a some basic torques Spark plugs 14/20- 1/4 UNF 6/9
5/16 UNF 15/20 - 1/2 UNF 50/65 - Gear box top cover 5/16 UNF 15/20 - motor mounts 3/8 UNF 24/32. Valve cover 1 to 2 lbs note to bend cover
Madflyer
Joel Lester
Can someone define what those numbers are that Madflyer used? for example... what does 14/20- 1/4 UNF mean? Just curious because I'm trying to figure out how I can "chase" the square nuts on the body work on my TR3A. I know they are fine threads but if I were to buy a tap and die set (or thread chaser kit) I'd like to know what size etc. to get?
Joel
bobhustead
I don't know what the 14/20 means, probably torque applicable to spark plugs. 1/4 UNF is a phrase in itself and means 1/4 diameter and 28 threads per inch, 28 being standard fine thread in 1/4 diameter. 1/4 NC is coarse, or 20 threads per inch. Fine and coarse thread pitch vary with the diameter of the bolt.
Bob
charleyf
Bob
I would suggest that 14/20 is really 14 to 20 lbs torque. These numbers have nothing to do with the threads per inch.
Charley
DavidApp
Coarse and fine threads also vary with the material they are intended for. Cast iron tends to get a coarse thread whereas steel will have a fine thread.
1/4" 20 is the UNC standard and 1/4" 28 is UNF standard.
David
Madflyer
Yes sorry that is the torque rang 14/20 14 to 20 lbs The Bentley TR book list every bolt and thread. You can be safe with fine thread taps and dies. But note there are three taps in most every size tap. STARTING- RUNNING- AND BOTTOMING taps they are used like they sound . Madflyer
Graham H
You would always be safe using the old mechanic's method, tighten it up until it strips then back it off half a turn, never fails.
Graham
DavidApp
Where I worked years ago we had an inspector who would go around an assembly checking the bolts were tight. He would always find that he could get another bit of a turn on the bolt and marked it lose on the inspection sheet.
One day an assembler got fed up with his attitude so the assembler tightened every bolt to the yield point so when the inspector did his normal thing every bolt failed. The assembler told him "put the spanner on the bolt and check it Don't add 1/2 a turn because I have got them done up correctly" He never had a problem again from the inspector.
David
Joel Lester
This is what I love about these forums... you gain knowledge, insight and... a great sense of humor as we learn about these fine British sports cars. Always good to have a handle on who is being sarcastic though! LOL!
Madflyer
Those that can do those that inspect well you know the rest. I had cement anchors inspected on a FED job 25% required a pull test. The test required a number of threads above the nut for his tool. I made sure they were the hardest to get to. A big job when 25% could be 50 test. I would walk away and the inspector would paint tested anchors. I think he spent more time painting than testing. Yes they all past. 5/8 3/4 and 1 inch anchors. Madflyer
Madflyer
I was a Elevator installer for 40 years. It is a trade that you do not mess with the good old boys. You name is our word and your work. As in the Ghost Buster's movie WHO YOU GONA CALL when things don't fit. Not the Engineer. Madflyer
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
T TR2/3/3A Question on TR3A front body mounting Triumph 6
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
T TR4/4A Body Mounting Strips Triumph 0
P TR4/4A Body mounting plate location? Triumph 2
O TR2/3/3A TR3 Body Mounting Hardware Triumph 1
A Body mounting to frame Triumph 7
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
martx-5 TR2/3/3A TR3 Body Mounting Triumph 1
M Mounting the body on the frame Triumph 11
G body mounting Racing 1
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
