TR6 TR6 Fuel Filter keeps clogging
bunzil
I've been through three tanks of gas on a new gas tank from Victoria British and the fuel filter has clogged twice to the point of where I was almost stranded. Examining the filter shows very tiny white fibers are the culprit. I did not wash the tank before installing it - perhaps now a mistake. Anyone have any ideas? My only theory, and it's a poor one, is that the box the tank was shipped in left these dust fibers behind, inside the tank.
Thanks
poolboy
If the filter is downstream of the fuel pump, the fibers might be the remains of a plastic filter screen in the fuel pump.
If the filter is up stream of the filter, I can't imagine.
dklawson
For the foreseeable future you may want to get the largest bodied translucent/transparent inline filter you can buy and use it instead of whatever your filter is now... and carry a spare. Eventually the fibers (whatever they are from) will all be washed out.
B
bunzil
Fortunately I long ago switched to a glass filter that unscrews from both ends so it's pretty easy to swap out the removable element. I'd really rather not remove the tank and flush it. Perhaps I'll just take your advice and have some spares.
Thanks.
George_H
Can't imagine its cardboard. I recall a story about a "former girlfriend" depositing "feminine product" in a tank resulting in similar issues. I hope thats not your case. What about getting a cheap electric fuel pump to empty the tank?
dklawson
Thanks.
I have one of those serviceable filters on the GT6 along with a petcock type valve between the tank and filter so I can replace the filter (which is under the tank) without draining the tank. I loose some fuel but not much!
Brinkerhoff
I'm in favor of carrying a spare and being prepared to change it out. One day soon you'll forget about it when the culprit disappears.
TexasKnucklehead
Not sure if it's related, but 2 people in our club installed new aluminum tanks. Both had several filters clog shortly after. Both have the glass/replaceable filters. Each time there was obvious crud, but don't think it could be called 'fibers'. We think it had something to do with the welds, on the inside of the tank that can't be cleaned. After a couple filter cleanings, it went away. I hope you are as lucky.
B
bunzil
The "glass replaceable filters" have admittedly a very small filter with not much surface area and so it wouldn't take much to clog it. I had mine in the car without incident until the current problem started happening. I went to a local auto store and bought the largest see-thru filter I could find and now keep the tank at half or less in an attempt to keep whatever this stuff is somewhat concentrated. If this crud is indeed in suspension I'll filter it faster if there is less gas in the tank at all times. Plus I'm keeping a spare filter in the trunk.
This will work itself out. Thanks.
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
