MGB Radiator fans - 1978 MGB
clyderedmond
After a nice short run this morning in 96 deg.F heat I parked the beast in the driveway. About 20 min. later I got back in and turned the key (not all the way to start) and heard a louder than normal sound from the fans so I looked under the hood to see and found only one of two running at quite a clip.
I turned the key off, then back to that position and neither cut on when the engine cranked. I am truely hoping this is a fuse or contact corrosion problem but with my luck it's probably worse. I don't have a good wiring schematic handy, so can anyone tell me what clour wires I might need to check or any other hints?
Thanks,
-Mike
1965_MGB
The wiring on the fans is brown/green, but I think you need to have a look at the wiring schematic.
You can find one online at www.advanceautowire.com. Click on the stock schematics button and it will take you to a .pdf of the wiring diagram.
Sorry I couldn't offer more help.
Joe Reed
That louder than normal sound you heard from the fans was probably from the bushings. Cleaning and lubricating the fan motors may solve the problem - at least for a while. I had that problem with one of mine. The clean and lube fixed it for a while, but not for long. Fortunately I was able to get a good used fan motor for $20 instead of having to mortgage the homestead to buy a new one. If either of them die again, I may switch to an aftermarket fan...
bob67bgt
Mike, i pulled a pair of fans from a rough 79 MGB parts car. They are untested and just gonna cost you shipping from NC if you want them. PM a address if you want them in the mail! Bob
C
clyderedmond
Bob,
Thanks - I appreciate it a lot.
My work address is Mike Osbourne
P.O. Box 280
Sullivan's Island, SC 29482
Let me know how much I owe you & thanks again
-Mike
C
clyderedmond
Robert,
Just a note to thank you again. I got them and will get them tested. I will put a check in the mail to you on Monday.
I suppose with temperatures in the upper 90's it would be madness to take Miss B out for a drive without having the fans working.
Cheers,
Mike
PAUL161
Cheers,
Mike
<span style="font-size: 11pt"><span style="font-weight: bold">I wouldn't!</span></span> JMHO. PJ
QuickSilver
PAUL161 said:
Cheers,
Mike
I would for sure. But just around the corner. My fan, even in the Texan 101 degrees doesn't come on till after 5 to 10 minutes of driving. I have an idiot light in the car wired to the fans so I can keep an eye on what "they" are doing.
Incidentally the light lit dimly when they are off and I am moving. Do you Guys think I am reverse charging my battery's?
J Radiator fans again! Austin Healey 5
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
D BT7 radiator Austin Healey 1
M Radiator Paint Austin Healey 20
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
