Spitfire 1978 Spitfire Horn trouble shooting
Joe_Pinehill
Im trying to trouble shoot the horn circuit on my Spit. I bought a
new indicator/horn switch and installed. the button was broken on the
old, so i thought that might do it. But when i press the button, I
dont see voltage at the horn.
I jumped each horn directly to the battery , drivers side does not
work, passenger side does.
The headlight dimmer high beam works, which I think is also on the
purple bus.
Im thinking the easiest thing is to just run a new wire from batter
to the switch with an inline fuse, and another from the switch to the
horns, with trying to find out exactly where the problem is.
The hazard flasher also does not work Im thinking this may be related to no voltage on the purple wire?
Any tips on abandoning wires in place and running new?
Bugeye58
Joe, I don't have a Spit wiring diagram handy, but isn't the horn switch in the ground side of the circuit? Purple hot at all times, and pushing the button completes the ground leg?
My memory is fading fast, but I seem to recall that if there are two wires to each horn, then that's the way it's done. A single wire hookup would ground through the horn body.
Jeff
guzzul
Joe - I think you are on the right track with your previous post. You should have voltage at the 'hot' (fused) side of the horn button on the purple wire circuit. The high beams should also come off that bottom fuse, so if they are working it shouldn't be the fuse itself.
Does your cigar lighter work? Ignition key lamp? Passenger lamp? All those are also coming off that fuse.
If those are working, and the hazard switch (which is 'south' of the horn button) is not, then it must be either a broken wire somewhere between the fuse and horn button, or one of the connectors in that chain is corroded.
I have had a lot of problems with the fuse mounting clips themselves. Usually though it will affect the whole circuit. Might be worth checking. There must be a junction somewhere in that circuit downline of the fuse - that would be my first suspect area.
Why not try a jumper wire from the fuse clip on the firewall around to the horn button? Disconnect the current horn button wire and run the jumper from the fuse mount to the horn button instead. If that works, and if all the other purple circuit stuff works except for the hazard switch you must have either a bad wire or junction. I would hate to leave a bad wire in there permanently, just in case some day it decides to short.
J
Joe_Pinehill
thanks guzal, staring at the wiring diagram i realize that none of the purple "bus" is working. I the high beams work but the dip does not. neither does the light, flaser, etc. I just got the car. Ill check the fuse, maybe a bad contact or fuse, or something hangin on the purple bus is shorted. I did get continuity when i demated the horn/turn/hi beam switch connector to the horn, so the purple/black wire to the horn is ok.
guzzul
Aha.
Watch out for the fuse mounts themselves. I have found them to be kind of dodgy and intermittent. The fuse itself may be ok, and if so try cleaning up the fuse mounting clips on that bottom fuse.
If you can get continuity between the fuse mounting clip and the horn button, the wire itself should be ok.
J
Joe_Pinehill
Re: 1978 Spitfire Horn trouble shooting, Solved!
After pouring over the wiring diagram, buzzing out, yes I realized to simply check the fuse, and yes it was blown. Replaced it, now I have 12 volts to the horns!, Hazard flashers that work!, and courtesy lights that shine!.
Hopefully the blown fuse was a fluke, or the next trouble shooting will be a why it blew!
The horns themselves are shot, anyone have luck with generic horns from NAPA?
guzzul
Could have been the horns themselves. If they are in bad shape they may be drawing too much current and blowing the fuse. Your Spit probably does not have a horn relay as earlier ones did, so a bad horn could conceiveably load up that circuit pretty good.
Did you replace the fuse with a British fuse? American 35A fuses will draw a lot more juice before blowing. If you're using and American fuse I would go with 25A or maximum 30A.
Bugeye58
Joe, if all you are looking for is audibility, the NAPA horns are fine. If I remember correctly, they have a decent variety to choose from.
Jeff
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
S MGB 1978, replacing the clutch. MG 3
M MGB 1978 mg fuel smell MG 23
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
S MGB Newbie 1978 MGB questions MG 11
TomR 1978 MG Midget with Points Distributor Spridgets 4
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
L 1978 mg midget seat belt replacement Spridgets 3
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
R ?'s re 1978 Midget MG 3
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
C MGB Radiator fans - 1978 MGB MG 11
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
J Windshield washer 1978 midget-bag on fender system Spridgets 0
regularman Its a 1978 and I want it. Spridgets 23
J Firing order 1978 Mg Midget 1500 Spridgets 7
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
M MGB 1978 MGB Headlight Ring MG 8
M 1978 Eleectrical issues MG 17
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
J 1978 MG Midget For Sale [florida area] MG 0
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
