MGB-GT 1978 fuel tank.. compatible with my 74.5 GT?
KLUTZ
I did a half arsed job on repairing the top of the gas tank out of the 74.5 GT 4 years ago when I REALLY didn't know what I was doing. The top had lots of little breakthrough spots on it and I used what was recommended at that time. I have a lead on a tank from a '78 which is supposed to be an aftermarket and fairly new to the vehicle. If the tank is better then the one I have, will it be a straight bolt in or will the design, especially with the venting, not work?
Thanks
Paul
Paul...I tried getting onto the Moss website, but it is currently down. I checked the Vicky Brit website...they have a different part numbers for the 1970-76 MGB compared to the 1977-80 MGB.
There must be some difference....but you may want to call Moss for clarification (I don't trust VickyBrit's help).
https://www.victoriabritish.com/features/mg/mgftl.htm
bob67bgt
The later tanks had the fuel line to the front right out of the sending unit. It will bolt right in BUT you will need the later sender. The location for the tank vent to the canister is the same. Bob
I'm pretty sure that the tanks were different from home market and export market.
In the States, the tanks were vented after 1969 or so...and I believe there were some changes (albei perhaps minor) in 1977.
This does not mean that the tank Paul wants to use will not work...it just may not be a simple bolt-in and go fix.
KLUTZ
KLUTZ
I just spoke to Jeff from Obsolete Automotive in Sarnia and he confirmed that yes, the tank will bolt in directly and yes, I would need the later model sending unit and slightly re-route the fuel line with a rubber hose. He also confirmed the slightly different angle of the filler pipe but stated with a little bit of persuasion, the rubber seal will fit around it.
Thanks for the responses, I am taking a look at the tank on Wednesday.
Paul
M MGB 1978 mg fuel smell MG 23
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
L 1978 mg midget seat belt replacement Spridgets 3
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
R ?'s re 1978 Midget MG 3
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
C MGB Radiator fans - 1978 MGB MG 11
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
J Windshield washer 1978 midget-bag on fender system Spridgets 0
regularman Its a 1978 and I want it. Spridgets 23
J Firing order 1978 Mg Midget 1500 Spridgets 7
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
M MGB 1978 MGB Headlight Ring MG 8
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M 1978 Eleectrical issues MG 17
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
J 1978 MG Midget For Sale [florida area] MG 0
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
AndreL TR6 Conversion to electric fuel pump Triumph 10
