MGB Drive Shaft U-Joint, 1978 MGB
tony barnhill
Great Pumpkin - R.I.P
no big deal - usually, for me, getting the driveshaft out from under the car is the bigee!
PAUL161
Tony I replaced the ujoints in a drive shaft on a 79 and one end was froze so hard that I had to put it in my press to break them loose. Before doing so, I milled a small piece of angle iron to fit between the yoke to keep from distorting the shape of it in the press. It worked very well. My 72 ujoints came right out with no problem. PJ /ubbthreads/images/graemlins/hammer.gif
jlaird
Ha, four bolts then take the whole thing to the machine shop and let him worry with it. I just hate U joints.
tony barnhill
8 bolts, Jim....4 on either end....then I just press them out
C Bugeye propeller/drive shaft- universal joint Spridgets 1
R Drive shaft universal joint bear cap modification Austin Healey 7
B Spitfire How do you replace U Joint on late model Spitfire OD Prop/Drive shaft? Triumph 7
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
R TR6 Drive shaft orientation Triumph 3
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
L TR2/3/3A Drive shaft question Triumph 5
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
R TR2/3/3A Maintenance on Drive Shaft Triumph 18
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
PAUL161 T-Series Balancing Drive Shaft MG 4
Gliderman8 TR6 One piece drive shaft? Triumph 6
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
S How much grease for the drive [prop] shaft plunger Austin Healey 3
S TR2/3/3A Distributor drive shaft play Triumph 4
S TR2/3/3A distributor drive shaft gear Triumph 4
CJD TR2/3/3A Overdrive Drive Shaft Triumph 4
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
W Drive shaft question Spridgets 8
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
D Paint the drive shaft... Spridgets 6
J TR6 TR-6 Drive Shaft Removal ? Triumph 4
T Question on Serviceability of Drive Shaft Componen MG 2
B Overdrive drive shaft? MG 8
AEW what is the short drive shaft? Triumph 5
pjsmetana New Lugnuts? Drive shaft Play? Triumph 7
MGTF1250Dave TR2/3/3A TR3 Drive Shaft Grease nipple Triumph 4
A Drive Shaft plat at differential MG 2
drooartz Which drive shaft? Spridgets 13
P Drive shaft won't come out of the transmission Spridgets 6
mountainman TR 3 Drive Shaft Question Triumph 6
jhorton3 Drive Shaft Spridgets 0
N TR6 Bolt size for TR6 Drive shaft? Triumph 6
ronzet MGA Late MGA 1500 Drive shaft dust cover MG 0
prb51 TR2/3/3A TR3 drive shaft flange issue Triumph 1
G How do I separate my drive shaft to lube splines Triumph 4
B TR6 TR6 Drive Shaft Cover Triumph 7
D drive shaft/rotor alignment British Motor Corp 3
guzzul Drive Shaft Balance Triumph 8
jlaird I need a drive shaft, Tony or anyone. Spridgets 9
H Towing 62BT7 with Drive Shaft Connected Austin Healey 4
B Drive Shaft Austin Healey 12
D Used Drive Shaft Coupling Needed British Motor Corp 0
D Unequal Drive Shaft Lengths British Motor Corp 3
T Mini drive shaft nut size. British Motor Corp 2
svtmikey Getting the hub off the drive shaft Triumph 3
M TR2/3/3A HVDA Speedometer Drive Triumph 10
