T-Series Balancing Drive Shaft
PAUL161
What's it cost to have a drive shaft balanced? Are the U joints left on when balancing? I pick up a slight vibration at 3500 rpm and not sure if it's the drive shaft, so I want it checked. The vibration only happens when on the road and at 3500 rpm. If the cost is over 100 bucks, I'll buy a new shaft assembly. PJ
Forgot to ad, the U joints are new.
Jim B.
Member
A vibration in that RPM range is common.
Usually not associated with the driveshaft.
As I remember it may be the "Roundness" of the front tires.
Check that out first.
Also check the tightness of the U bolts on the rear axle.
Jim B.
Grantura_MKI
Should be under your estimate. On a T type you can pull the cover off and drive. Check the rear Trans mount and drive to see if you have a balance issue.
LarryK
Put it on a lift, make a holder for a piece of chalk or crayon. Start car and put in high gear to keep rotation slower and move chalk or crayon closer to shaft until it starts marking on the heavy side. You can temporarily balance with a hose clamp, moving screw clamp side to the opposite of the mark until it levels out. Take shaft in and have it weighted and permanently balanced.
Jim B.
Member
Three other things to check,
1) From the WSM. The sliding Joint is always at the Gear Box end.
2) The U-Joints are in line.
3) If 1 and 2 are OK, Rotate the input joint 180 degrees.
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
HealeyRick Proof of Concept - Drum Balancing Austin Healey 21
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
HighAltitudeTR3 TR2/3/3A Balancing Wire Wheels... Triumph 4
parkerg1 TR2/3/3A Balancing Wheels Triumph 13
vette Wheel Balancing Beads Austin Healey 3
N Wheel balancing?? Spridgets 5
PAUL161 General MG Wire wheel balancing service MG 2
S TR2/3/3A Wire wheel balancing Triumph 16
CJD TR2/3/3A Crank balancing Triumph 11
tahoe healey DYI wheel balancing Austin Healey 1
D Balancing Beads For Tires Spridgets 6
RJS Balancing a radiator fan[?] Triumph 18
D Balancing Beads Austin Healey 32
mrdibbles Balancing Wire Wheels - While mounted on the car Austin Healey 18
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
L Balancing wheels and cowl shake, part 27 Austin Healey 5
RAC68 Wheel Balancing Hub Adapter Austin Healey 5
roscoe Tire balancing beads Austin Healey 4
J Balancing Wire Wheels - Old Method? Triumph 3
P Wire Wheel Balancing Triumph 7
pjsmetana Prop Shaft Balancing Triumph 12
PSJ Seattle area wire wheel balancing Spridgets 3
R Engine Balancing ? Triumph 11
G Trouble balancing steel wheels on '79 Spridgets 2
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
davidk TR6 TR-6 Flywheel balancing Triumph 1
D Balancing Connecting Rods Triumph 17
angelfj1 RoadForce Tire Balancing I Don't Understand??? Restoration & Tools 4
58Custom What are the tricks to balancing wire wheels? Spridgets 8
Geo Hahn Tyre Balancing Triumph 13
Tinkerman TR2/3/3A Balancing a TR3 fan assembly Triumph 7
tahoe healey wheel balancing Austin Healey 14
Tinkerman TR2/3/3A Balancing TR3 Fan Assembly Triumph 6
NutmegCT H6 carb balancing Triumph 8
zimmy Carb Balancing Tool Spridgets 7
Darwin A Balancing Act Triumph 1
prb51 Balancing Act Triumph 1
R Wire wheel balancing Triumph 10
A Carburetor balancing MG 7
M fan balancing Triumph 3
T Wire Wheel Balancing Triumph 8
A SU balancing on BJ8's Austin Healey 4
Randy Forbes Balancing Carbs... Austin Healey 3
T Balancing wire wheels Triumph 4
Bob McElwee Wire Wheel Balancing 'Adapters". Restoration & Tools 2
B Source for SU balancing tool ? Restoration & Tools 7
M TR2/3/3A HVDA Speedometer Drive Triumph 10
B MGA Tach drive issue MG 1
