Trouble balancing steel wheels on '79
G
Well, I pulled my '79 out again and dusted it off only to find I had ply separation on two tires. No problem as I had three new ones ready to go on after I repainted my wheels. I balnaced them out once before using my buddy's machine but can't quite get two of them to "remain true". Every time you take the wheel loose and put it back on the machine it'll read different. I tried "coning" at the back and front of the rim. The front has more consistant results. That's how I balanced them out the first time. The smallest cone barely catches the front of the rim hole. I'm starting to suspect these rims are lugcentric only and not hubcentric at all.
I'm considering having an adapter made w/ studs so I can bolt them on the balancer and be done w/ this headache, however; I don't know if my buddy will still have the machine as he is selling his shop.
Any tricks to balancing these wheels?
Thanks, BIlly
bthompson
I think I remember reading somewhere that the wheels <span style="font-style: italic">are </span>lug-centric, and using a 'normal' balancer won't work. Hopefully someone else hereabouts can fill in more details.
bill_young
Bill is correct. For the rostyle wheel you can't count on the front hub opening and rear area between the lug nut pads being true to the wheel center. You need some sort of centering device for the rear that locates on the lugs instead of coned to the wheel center area. Similar to the locating problems the guys with wires have on balance machines as well. If you have a friend who is a machinest you can either have a disc turned and drilled or some just machine down the front and rear of an old hub and use that. Once the rear is correctly registered on the machine the front will work out ok and you can balance the wheels ok.
T General Tech Clutch trouble Triumph 12
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
sparkydave Trouble running hot Spridgets 10
F General Tech trouble with editing post Triumph 2
HealeyRick Tach Trouble Spridgets 2
JPSmit Trouble posting pics FORUM Navigation Questions 2
D Tune Up Trouble Austin Healey 24
G TR6 Clutch trouble Triumph 4
J Powertune booster for a bj8 , trouble installing Austin Healey 2
T Trouble inserting pictures to post FORUM Navigation Questions 2
R TR6 Trouble with TR6, carb now??? Triumph 6
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
C First Gear Trouble BN1 Austin Healey 5
L Trouble refitting pulley to new water pump Spridgets 9
C bugeye trouble spots Spridgets 5
C what are the trouble spots on a bugeye Austin Healey 1
RickB MGB Trouble bleeding new clutch MC & slave MG 6
B sprite engine trouble? Spridgets 2
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
R Lower wishbone bushing installation trouble Austin Healey 9
F MGB '76 MGB ignition trouble MG 62
S Electrical Trouble Shooting Spridgets 8
longbridgehealey Big trouble with BN4 brakes Austin Healey 53
MG Lily T-Series MG-TD Battery Trouble? MG 4
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
smaceng TR6 Trouble with a TR6....body! Triumph 10
bighealeysource Trouble getting toe in done on BN2 Austin Healey 16
J Having trouble getting Forum to work on IE 9 since it was switched to the new format. FORUM Navigation Questions 7
P Flasher trouble shooting - pls help Austin Healey 6
Morris I could be in trouble here... Spridgets 17
M Another Ebay trouble child? Spridgets 39
glemon Trouble Lights for Cheapskates Like Me Restoration & Tools 3
TulsaFred First start trouble rebuilt 1275 Spridgets 29
dvmmatt steering trouble Spridgets 17
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
H Trouble shooting gas gauge...any hints? Austin Healey 9
S trouble shooting not working speedo or testing one Triumph 22
theleisure Trouble Dropping Motor into Mounts Spridgets 14
T Trouble restarting after a drive Spridgets 11
G Sway bar mounting area trouble? Spridgets 14
rlich8 TRouble with the TRans tunnel and Speedo Pinion Triumph 4
G DCOE trouble/qusetion Spridgets 10
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
Tremelune Starter trouble--Local lifetime replacment? Spridgets 54
R engine trouble, need advice Spridgets 16
Don_R Spitfire Spit trans trouble Triumph 19
smaceng Engine Trouble? Spridgets 7
G Trouble getting flywheel ring gear on. Spridgets 23
RickB MK2 Sprite - new windscreen to body seal - trouble Spridgets 21
