Hi guys,
I'm in the middle of the process of dropping a 1275 in to replace my 1098 and I've hit a snag. I can't get both of the front rubber mount bolts to drop into the hole in the pedestal. I can do one or the other but not both. It will drop in as low as the hole for the pin but the hole for the bolt is just a little lower. It seems like the 1275's mounts must be a 1/4" wider than the mounts on my 1098 are. I'm using the same rubber mounts and mount pedestals that attach to the car so it can't be related to those. I had the 1098 in and out a few times and never came across this issue before.
Any advice would be appreciated.
thanks,
Sean
thanks,
Sean
