PrintedGear
I just replaced the rubber around my front flashers. Now, when I turn on the signal, the light stays on. It did blink before. I've switched the two shorter wires to the bulb with no change. This is the older style push through the hole type connector.
Also, since im asking. The right signal never worked since I purchased the car. I hear no click in the b810 relay when I switch to the right. How can I troubleshoot this?
Thanks!!
Thanks!!
