When steering wheel is turned to the right, the right hand flasher is activated. Does not happen when wheel is turned in opposite direction. The directional/horn hub on the steering wheel rotates with the wheel but can be rotated independently of the wheel by hand.
Obviously there is a wire moving or loose within the hub. I've read that removing the three screws at the wheel will open up a larger can of worms (because of the stator tube that runs the length of the column?). How can I access these wires? Can the directional/horn hub be locked with the wheel so that it can't be rotated independently?
