Flasher Unit
PeterB
The driver's side flashes slower then the passenger's side. Am I safe to assume the flasher unit is going, or is there something else to check?
Thanks,
Pete
John Turney
The driver's side probably has more resistance than the passenger's side. Check for corroded connections. The flasher unit is driven by heating of the element from current flow - less flow, slower heating.
twas_brillig
check your bulbs as well as the connections. In the eville old days (pre LEDs, etc.) the change in flasher speed usually meant that a bulb had passed away. Doug
P
PeterB
More info to add to my puzzle. So, in checking all my grounds and connections over the weekend I noticed that when the driver's side blinks slow you can hear the flasher unit that the 3 wires connect to make a tik tok noise. When the passenger's side blinks fast, no noise is made.
mezy
I know its a stupid question, but have you changed a bulb on the passenger side, they should be 21 watt bulbs,
If you have fitted a 5 watt side lamp bulb by mistake it would give the symptoms you have.
Since the flasher unit serves both left and right flashers, and one side is working i would asume it is not the flasher unit.
I have also come accross where someone fitted a double fillement bulb 180 degrees out, gave then a nice bright side light
but a dim flasher.
T Lucas Flasher Unit Austin Healey 5
B Flasher Unit Austin Healey 1
BN6_2197 How does the flasher unit work Austin Healey 4
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
R TR2/3/3A Flasher Unit, A Clue? Triumph 11
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
G TR4/4A Flasher Unit...VERY hot Triumph 10
pkmh Humorous moment while detailing Healey flasher unit Austin Healey 5
B TR2/3/3A Flasher Unit operation Triumph 4
H Up-dated Flasher Relay Unit for Austin Healeys Austin Healey 1
R 100-4 flasher unit buggin' me Austin Healey 2
sundown TR6 1973 TR6 flasher unit Triumph 1
hondo402000 TR6 hazard flasher unit for 69 70 71 TR6 model Triumph 22
prb51 TR2/3/3A TR3 Electrical issue flasher unit Triumph 3
B Flasher unit Spridgets 1
jdubois TR2/3/3A Flasher unit location on TR3A? Triumph 13
ncbugeye side-flasher unit Spridgets 3
kch Flasher unit burnt up Austin Healey 5
sultanoswing Upgrading turn flasher unit? MG 5
H healey 100 flasher unit Austin Healey 3
1 Midget flasher unit Spridgets 3
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
6 Turn Signal Flasher Spridgets 8
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R For Sale Misc. TR-4 signal and flasher parts Triumph Classifieds 0
N Turn signal flasher?? Spridgets 8
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
Lukens TR2/3/3A Led flasher relay? Triumph 3
PAUL161 T-Series Turn Signal Flasher MG 8
RAC68 Lost 8 terminal Flasher Relay Plan Austin Healey 39
Gliderman8 TR6 Correct LED flasher relay Triumph 6
F TR2/3/3A Direcional Flasher Problem Triumph 12
Jim_Gruber Turn Signals and Flasher Lamp on Dash Spridgets 8
Marla TR4/4A Flasher Triumph 10
K TR2/3/3A Correct position for flasher bracket? Triumph 7
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
KVH TR4/4A Turn Signal Flasher and Perceptions Triumph 3
KVH TR4/4A Three Questions: Distributors, Idling, Turn Signal Flasher Triumph 29
G TR2/3/3A Flasher mount Triumph 12
sundown TR6 1973 TR6 flasher question Triumph 6
K TR2/3/3A Turn signal flasher stays on? Triumph 3
T TR2/3/3A Flasher indicator dash light Triumph 3
T TR2/3/3A Flasher problem Triumph 12
I TR6 Any tips on removing flasher switch Triumph 3
I TR6 Turn/flasher help Triumph 8
BN6_2197 Question on flasher of BN6 Austin Healey 28
T TR4/4A Question on mounting front flasher lights Triumph 6
D TR4/4A Elec Flasher/LED bulbs revisited Triumph 14
M TR2/3/3A Rear flasher lamp replacement Triumph 10
R Diagnosing flasher relay Austin Healey 4
