Starter trouble--Local lifetime replacment?
Tremelune
Member
So, my starter just goes "whiiir" after I beat on it today. Previously, it would whir every now and again, but would be fine if I gave it another shot. It continues to spin with enthusiastic fervor, but now it doesn't engage the motor. I very much want the car to be drivable this weekend. There is a lady involved, and even the best of them prefer not to push me around as a matter of course.
After doing some research here, I'm going to pull the starter and monkey with it and see if a simple cleaning and some graphite fixes things, but if I can go down to Kragen/Napa/AutoZone near San Francisco and buy a $50 replacement that will last another ten years, I'm not going to mess around too much (unless it's super easy to get in and out--writeup?). I wouldn't mind replacing it with a modern "upgrade" either.
Are these common parts for a 1965 Sprite (part number)? If I can get one tonight before the store closes, I would feel a bit better. I feel like a 1971 Plymouth replacement part might also be pretty rare...
Worst case, I think the one that's in there is a lifetime Bosch, but I don't want to lose a day figuring out that, yup, it's broken or waiting for anything to be shipped.
Deleted member 8987
NAPA, NAE 16121, or PME 16121
Same starter, different "level" and price.
Tremelune
Tremelune
Member
Wow and wow, thanks. The NAE has a "limited lifetime" warranty and the other has a three year warranty. I didn't know Napa got a good parts searcher...Too bad they just closed.
spritenut
You don't have to jack up a Sprite to replace the starter.
It's a bend over the fender job but a helper to hold the inside bolt in the slave hole helps or a strategically placed 9/16 wrench in the hole as you use a ratchet from the top side reaching under the starter.
I just did one tonight, 10 minutes tops.
Tremelune
Tremelune
Member
You've gotta be kidding me--How do I get at both ends of that bottom bolt?? Will the starter fit out without removing the distributor? I guess I'll take another look.
The manual I have ain't that helpful.
jlaird
Easy stuff, we have all done it. Like the man says 10 min tops including finding the correct wrench.
Tremelune
Tremelune
Member
Well, I got it off. I had to use two 9/16" sockets with extensions. I managed to get it out through a hole in the floorpan that (I believe) the previous owner enlarged for this very purpose...It was a very tight fit. I don't know how I'll get this thing back in the car.
When I pulled it, I was dismayed to find a great deal of sludge and metal filings attached to the starter through-bolts as well as the internal wall of where the flywheel is. Here are two shots, the latter after I swiped through the sludge with a finger:
Should I be worried about this? I can only see a few flywheel teeth, but they look fine. The gears on the starter also look fine (though I don't know what I'm looking for):
The sleeve that engages the starter to the flywheel, on the other hand, shows signs of wear...though it doesn't seem to be from rubbing the starter gear. I'm not sure what it could have been rubbing:
I tested the starter on the bench, and when power is applied, the sleeve leaps to engage the starter gear. When I apply power while it is spinning down, the sleeve spins, suspended without engaging. When I let it spin to a stop, and then apply power, the sleeve leaps to engage again. Turning the sleeve with my hand, there is a <span style="font-style: italic">slight</span> feel of friction about mid-way through...Very slight.
My guess is, if I cleaned it up and put on some graphite, it would last a while longer. That said, it's a 13-year-old remanufactured part...one which isn't much fun to replace. I'm going to see if I can find a "new" part locally. If I can save myself from doing this again next year (or this weekend), I think it'll be worth it.
Tremelune
Tremelune
Member
I was happy see what appeared to be a new, beefy power cable on the starter. I was not happy to see this ground strap attached to the frame:
Thing isn't even insulated...The starter has always felt like it receives good power, though.
G
O.K not to insulate a ground. Chabge if needed and clean up your contact points on the frame, starter etc.. I got mine from Pep for $50, but now am having trouble getting replacements as they don't carry or list it anymore.
Morris
Sorry to say... but it looks like you have a chewed up ring gear. You can hook the starter up to 12v with a pair of jumper cables. If it jumps to life, the culprit is your ring gear (the gear teeth that surround the flywheel). You can re-install the starter, then push the car forward in gear. This should expose the starter to some good teeth on the flywheel. If the starter works after that, you know your culprit is the ring gear.
Tremelune
Tremelune
Member
Is there any way to inspect the entire ring gear? I guess I could put it in top gear and try to spin the rear wheels...
Presumably replacing the ring gear is a big deal.
The starter issue started about a mile down the road (I bumped it and drove home), so the position of the ring gear has changed since then (in other words, here's hoping it's the starter...)
sim
I had enough starter to keep repairing one to good working condition. However they would always fail in a year or 2. will I finally ran out of parts and was forced to buy a new one. It has been trouble free for years
Buy a good new one and save the starter ring. Had to replace that due to bad engagement
Tremelune
Tremelune
Member
I checked out the ring gear by putting the car in top gear, wedging something underneath one of the wheels, and taking turns rolling the other wheel forward and looking at the ring. Looks find to me.
I wiped out as much sludge as I can from the housing and cleaned the gear/bendix with half a can of brake cleaner. I'm going to put some dry graphite on there, put it back in the car, and hope for the best.
One thing I wish I had done before pulling it was try jumping the car with my truck. From what I've read, a weak current to the starter (due to corrosion or a weak battery) can cause the starter to spin, but not spin fast enough to generate the centripetal force necessary to engage the bendix. My starter has always been very strong, but I probably used a lot of battery juice trying to get it going that last time.
Deleted member 8987
ANY Bendix will do that with low enough batery.
It's the inertia of a fast jolt that slings the Bendix in.
G
Which side you looking at? It's the backside you need to be concerned with.
Tremelune
Tremelune
Member
Well, I feel a bit defeated. I got the starter lubed up with dry graphite, felt the bendix move freely and spin back, and reinstalled the starter...Same thing. It just spins without engaging the ring gear.
I jumped the car with my truck. I bridged the ground strap on the motor directly to the battery. I applied power directly from the battery to the positive post of the starter motor. Lights are still bright. Same thing every time. A strong whiiir and no engagement.
My only real recourse at this point is to take the starter to an autoparts store and see if they can test it "under load"...I don't get it. I stuck it in a vice and applied power and it sprang to life, bendix and all. Is there something special I need to do to install it besides shove it in there??
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
