MGA Change a pull starter to a push button system
Coastalman
Years ago on one of my first MGAs a mechanic at the local MG dealership converted my pull starter to a push button starter switch. Has anyone done this and, if so, what parts and how were you able to do this. I don't remember any details from that far back. I do know that it was a lot easier to use.
Thanks,
Charlie
pdplot
I did this on my first TD many years ago. Don't remember the details, but get yourself a wiring diagram and you can probably figure out how to wire it between the hot wire and the starter and a ground wire to complete the circuit. One of the experts on here can tell you better than I the details. It can and has been done.
Grantura_MKI
I would fit an early MGB starter solenoid and ignition switch and do way with the pull switch.
All wiring will be present save for the trigger wire that will need to run from the ignition switch via the same route as the cable to the Solenoid.
Remove the pull cable, as it can act as an earth and cause damage.
C
Coastalman
D,
Thanks for the suggestion. I think having a separate switch for starting the car is kind of cool. I found an old big Healey solenoid in my shed from a few years ago when I had a big Healey. It's NOS so I think I'll try that with a push switch. Another car friend of mine send my a link to O'Reilly's Auto Parts store list of push switches. I'll head up there tomorrow.
Charlie
Grantura_MKI
A push switch will work as a trigger once you replace the solenoid. Was worried that you where attempting to use the original unit, and the push switch wouldn’t stand the load.
Good luck with it!
billspohn
If you want a stock look for the dash, I suggest that you buy a starter switch and knob from a TR-3. See > 550-000 KNOB, starter switch | Moss Motors < for the knob. Buy a solenoid like this > 546-020 SOLENOID, starter | Moss Motors < and I'd suggest having a tab welded on the frame lower down than the stock mechanical starter switch lives. You could hide it under there and the button comes in very handy for bumping the engine over when setting valves etc. If you want a stock under bonnet look, leave the mechanical switch on the stock bracket and just disconnect the heavy cable from it and connect it to the new one mounted below. 'Stealth' installation.
I use the TR3 switch on the Jamaican MGA (pic taken during build). The button is to the right of the centre at the bottom below the fuel gauge. That way I was also able to keep the stock ignition switch.
C
Coastalman
Today I finished installing a push button from an early big Healey. I only had to enlarge the hole a little bit so I can put things back to original if I want to. I installed a modern six position fuse block so I could get power to other accessories. I also used an extra NOS Healey solenoid that I has left over from my big Healey. All is working just fine.
Charlie
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
D TR2/3/3A Why it is important to change brake fluid Triumph 4
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
T BJ8 Fan Belt Change Austin Healey 7
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
T TR4/4A Core Plug - Cam Rear change Triumph 7
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
M Change LHD for MOT Other Cars 2
R Master Cylinder change working Austin Healey 12
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
davidb AH 3000 - vinyl colour change Austin Healey 7
6TTR3A TR2/3/3A Production Change Triumph 7
Michael Oritt Oil Change Problem Austin Healey 27
M MGB trying to change rotors - dumb question MG 7
C Color change...impact on Value? Austin Healey 24
JPSmit How often do you change your spark plugs? Spridgets 7
Basil Admin Note One more little change MG 1
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
E Oil Change Austin Healey 1
dcoplan Spark plug and oil change question Spridgets 9
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
toysrrus What? I`ll have to change my avatar again! Triumph 13
hondo402000 Oil Change Triumph 6
Moseso A simple oil change gone South Triumph 16
J Any reason to not change the color of a Sprite? Spridgets 10
Gliderman8 Oil Change.... When to do it? Triumph 17
Marvin Gruber T-Series TD diff change & wire wheels MG 9
Anthony_S Oil Change Triumph 13
5 BN4 cylinder head casting change date? Austin Healey 5
AUSMHLY When to change oil ? Austin Healey 12
N Head Change???? MG 2
Woodie TR6 tr6 oil change Triumph 5
Rut 1275 oil change Spridgets 6
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
drooartz Time for an oil change: filter and jack stands MG 7
F Change BE tach to electric Spridgets 3
