Oil Change
Anthony_S
Okay, so this is probably going to seem pretty silly but I am changing the oil on my TR3A this evening for the first time since I have had it, which is only last fall. I was wondering if there is anything special I should know or any tips and tricks. Im sure there is a thread out there about this but I thought I would ask.
Thanks so much!
Anthony
gubba
I use 20/50 castrol and ZDDP...
Andrew Mace
If you still have the original replaceable cartridge oil filter, just be absolutely sure you a: have the correct new gasket for the cannister, and b: that you make sure to remove the old gasket. Doubling them up seldom does anything but annoy you as you attempt to mop up several quarts of fresh oil from the garage floor! :madder:
TR3driver
Great Pumpkin - R.I.P
Stock canister filter, or spin-on adapter?
If it's the stock canister, then you need to be sure to pry out the old gasket from it's groove, and clean the groove to be sure there weren't two of them in there. It's ironic, but with two gaskets you are almost certain to have a leak.
When you reinstall the canister (after cleaning it and dropping in the new filter cartridge), make sure the edge of the canister enters the groove in the head. There is supposed to be a seal between the flat washer (under the bolt head) and the body of the canister, which has been missing on many cars that I've seen, causing a slow leak at that point.
Don't forget that there are a lot of places that should get a drop of fresh oil at each oil change. Door hinges, pedal pivots, throttle linkage, distributor shaft (under the rotor); to name just a few. Get a copy of the owner's manual and follow what it says.
Anthony_S
Anthony_S
Thanks for the input. It is the stock canister filter. Can you get that gasket at your local auto store?
TR3driver
The gasket should come with the filter cartridge. (Actually, they usually come with an assortment of gaskets and you have to pick the right one.)
If not, you should be able to buy it from the usual LBC suppliers (Moss, TRF, etc). Very unlikely you would find it separately at an auto store, IMO, but it's possible.
Anthony_S
Anthony_S
Okay great, I should be good to go then. I already have the filter. Thanks for your thoughts. What is ZDDP?
elrey
Zinc dithiophosphate, an anti wear compound that used to be more prevalent in engine oils. With the advent of catalytic converters many companies reduced the amount of zinc in their oils as it was believed to interfere with, if not ruin, the converters.
TR3driver
Geo Hahn
Also (in case you haven't read ahead in the manual) be sure you have enough oil on hand. The 4-5 quarts you put in your Honda or Toyota won't do it here. You'll probably want 7 quarts of what you're using to be sure you have enough to fill to the correct level.
Hoppy_H
I recently purchased Valvoline Racing Oil 20W50 for my TR4. It still contains that ZDDP stuff.
Hoppy
Anthony_S
Anthony_S
Hey everyone thanks for the input :smile: I put it up and drained the oil and got the filter off without a problem....wow a lot of oil came out, more than i expected....almost overflowed my pan haha. Filled it with the racing oil like mentioned above and no leaks or drips so I would say it was successful!
D Overdrive Stops Working After Oil Change Austin Healey 26
Gliderman8 TR6 Would you change oil? Triumph 5
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
Michael Oritt Oil Change Problem Austin Healey 27
E Oil Change Austin Healey 1
dcoplan Spark plug and oil change question Spridgets 9
hondo402000 Oil Change Triumph 6
Moseso A simple oil change gone South Triumph 16
Gliderman8 Oil Change.... When to do it? Triumph 17
AUSMHLY When to change oil ? Austin Healey 12
Woodie TR6 tr6 oil change Triumph 5
Rut 1275 oil change Spridgets 6
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
drooartz Time for an oil change: filter and jack stands MG 7
robdmau New to a Sprite, oil change questions... Spridgets 35
memphis Oil Change Austin Healey 23
B TR6 TR6 rear axle oil change Triumph 21
RJS Oil and Filter Change [how much oil?] Triumph 2
prb51 1st oil change on rebuilt motor Triumph 4
livinginthepast This may seem like a stupid oil change question... Spridgets 5
Stewart 7 quart oil change MG 4
T Oil Change, type of oil Jaguar 2
Monark192 MGB-GT 67 GT Overdrive trans oil change question. MG 6
J TR2/3/3A Oil Change in a TR3 Triumph 19
Lynn Kirkpatrick Oil Change Suckers? Restoration & Tools 12
C rear end oil change Triumph 17
W Silly question Gear Box oil change/top up MG 11
J First oil change after rebuilt and head torque Spridgets 6
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
S oil change and starting Triumph 9
J Information to Latest the Triumph Wiki -oil change Triumph 2
F TR6 TR6 oil looks dirty soon after change... Triumph 6
B TR6 TR6 Oil change Triumph 13
Wana Gearbox and differential oil change Austin Healey 8
Whytock Oil Change MG 6
J TR6 first oil change on a TR6 Triumph 1
J TR2/3/3A TR3 Oil Change Triumph 8
hondo402000 Differential Oil Change question Triumph 11
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
RSMTR8 Wedge TR8 Oil Change Triumph 9
nevets oil filter change procedure Austin Healey 22
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
PAUL161 Thanks Doc & Tony -OD & transmission oil change MG 0
A Spitfire How to change diff oil on 78 Spit? Triumph 1
S oil change Triumph 15
W TR6 How to change oil filter on a 1975 TR6 Triumph 13
