MGB-GT 67 GT Overdrive trans oil change question.
Monark192
I see a drain plug on the transmission and another marked drain on the overdrive, but where do I re-fill??
bob67bgt
there is a plug behind the radio console. Reach your fingers thru the hole and pull the dipstick. Refill thru that hole with a flex funnel. Bob
Platinum
Motor oil, BTW.
vping
Bronze
20/50 and add a piece of string or a zip tie to the dipstick on the fill so that you can pull it back out again when you need to. It really helps.
Monark192
Monark192
Thanks everyone. I will do that one evening this week. The car took its first tentative trip around the block today so things are getting exciting.
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A overdrive trans Triumph 11
S TR2/3/3A Test an overdrive trans. Triumph 6
T TR2/3/3A TR3B overdrive trans fluid Triumph 12
J TR4/4A TR4 Trans/overdrive repair shop in Upstate NY? Triumph 7
A Trans/overdrive questions MG 5
S TR Trans Rebuild - Removal Of Overdrive Pump Cam? Triumph 4
SCguy Overdrive question on my rebuilt trans. Triumph 6
B Mobil 1 Synthetic 5W30 in Overdrive/Trans Austin Healey 7
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
