Overdrive Not Engaging
Panther
Was driving Healey the other day, tried to engage overdrive, but it did not kick in. I pulled into the garage and checked overdrive oil. It was at minimum at bottom of dipstick. I filled it with 30 weight oil. Took car back on road. Overdrive still not working. I heard the click of the solenoid, but the overdrive was not engaging. Not a lot of miles on overdrive. Did not drive vehicle with overdrive oil low much at all. Any ideas on what it could be? Car has very low miles.
Since your solenoid appears to activate your electricals are working (which is the most common cause of O/D problems). Minimum oil should be enough to prevent damage, so my first guess is your oil got aerated, which could prevent sufficient operating pressure (like spongy pedal when brake fluid gets aerated). Let the car sit for a day or so, then try again; if it still doesn't work then it could be the hydraulics, but those don't usually fail without warning (slower and slower engagement).
Another (better) possibility is your solenoid is working, but the lever that rotates the cross rod that opens the activating valve is slipping on the cross rod; this could happen suddenly. You didn't mention what model Healey you have; earlier cars have this lever exposed, but later cars have this enclosed, and I don't know if you can get the cover off the box in situ. If the lever moves but the cross rod doesn't you have your answer; you will need to adjust and tighten the clamp on the lever.
I'm not sure what you mean by "Car has very low miles;" some have taken to resetting the odometer after doing a restoration (it's not hard to do). Healeys with less than 50K 'true' miles are pretty rare.
P
Panther
Hi thank you for getting back to me car was Total Restoration in 1979, 5000 miles on it since then, Austin-Healey 3000 Mark III.
John Turney
I agree with Bob, that it could be the operating lever under the solenoid could have slipped.
Another possibility is that the click you are hearing is the overdrive relay on the firewall and not the solenoid. It's best the check the sounds with the engine off and the key on, unless you have a Pertronix ignition which doesn't like being powered on without the car running.
P
Panther
Thanks
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
BN6_2197 Overdrive engaging with time delay Austin Healey 39
60TR3A Overdrive Not Engaging Triumph 7
BN6_2197 Overdrive not engaging when engine warm Austin Healey 15
L engaging and disengaging the overdrive Austin Healey 3
K Engaging Overdrive Austin Healey 5
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
R TR2/3/3A Overdrive wiring installation Triumph 14
P Broken Overdrive Switch in Gear Knob Austin Healey 14
