TR2/3/3A J Type Overdrive in TR3A
RonC
RonC
I have a fully rebuilt J type OD from a 1973 TR6. I was planning an install through the cockpit into my 1958 TR3A which has a TR4 block. The plan was to keep the TR3 spring clutch since it has next to no miles on it. I now found that the input shaft front cover on the TR6 transmission has a sleeve for the release bearing/sleeve that is 1 31/32 inches in length. This would accommodate the diaphragm clutch. The TR3 transmission with 3 finger spring clutch has a front cover with a sleeve length of 2 3/8 inches. I am now stuck with do I go further down the rabbit hole with a clutch change?
My understanding is that the diaphragm clutch will require modification to the flywheel for mounting and isn't just a simple bolt on with same holes as the TR3 clutch? Can the front covers, with different sleeve length, be just unbolted and changed and then I proceed with sliding the transmission back on my block with TR3 clutch?
Will someone with a TR4 A type OD transmission want to consider an exchange for a professionally rebuilt TR 6 OD unit?
Ron
RonC
RonC
So far it looks doable and I can rob the TR3 cover from my removed transmission. Macy's Garage had a short Aug.14/18 blog about the varying sleeve lengths and hangup of clutch fork/bearing in travel if mixing up parts. They never did note if they stuck with the older 3 finger clutch with appropriate cover, fork/bearing or switched totally to TR6?
CJD
That's the easy fix. I think the short snout will even work in place of the long snout...but I can't confirm that for sure. The long snout will NOT work in the newer, diaphragm clutch, as it will hit the diaphragm.
RonC
RonC
I was hoping that there would be other TR3/TR4 early frame owners that could give feedback on their rear J type overdrive gearbox mount. It is amazing how creative gear heads can be in fabricating or finding a custom mount that works! Someone out there?
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
