Oil Change
hondo402000
first this has nothing to do with a Triumph except that my TR6 was Close by, My 1997 Chris Craft boat needed an oil change after the new engine I put in it, dont ask.... and after 20 hours of run on break in oil. As any one knows changing oil in a boat is difficult at best, no drain plug in the pan. so after 4 hours of thought I came up with putting a heavy duty trash bag under the engine, and unbolting the dipstick tube, drain the oil in the trash bag and slide the bag out of the engine bay, without punching a hole in the bag and dang, It worked like a champ!
so if you have an inboard outboard and want to change your own oil thats an easy way
thats all
Hondo
PAUL161
A dip stick suction pump is easier and no mess! There are various kinds, powered or manual. All depends on how much you wish to spend. Here's a couple of many. PJ
hondo402000
hondo402000
actually I bought one, its got a 12v motor but it never worked very well. maybe I didnt get the oil hot first but its a pain to run the boat in the drive way long enough to get the oil hot so it can be sucked out, so the oil bag thing works well, and anyway you do an oil change its messy
Hondo
CJD
But will it draw out the large chunks of broken metal I always have in my engines?
John
TonyPanchot
Just ordered the one in the Picture, Just spent the weekend changing oil on the LBCs should make the job a bit easier, now for a way to make an easy swap filter
hondo402000
hondo402000
well the only problem with an inboard boat engine is there is NO Oil drain plug!
you have to have it sucked out or do as I did, and sucking out the oil never gets all the old oil out, IMO
Hondo
D Overdrive Stops Working After Oil Change Austin Healey 26
Gliderman8 TR6 Would you change oil? Triumph 5
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
Michael Oritt Oil Change Problem Austin Healey 27
E Oil Change Austin Healey 1
dcoplan Spark plug and oil change question Spridgets 9
Moseso A simple oil change gone South Triumph 16
Gliderman8 Oil Change.... When to do it? Triumph 17
Anthony_S Oil Change Triumph 13
AUSMHLY When to change oil ? Austin Healey 12
Woodie TR6 tr6 oil change Triumph 5
Rut 1275 oil change Spridgets 6
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
drooartz Time for an oil change: filter and jack stands MG 7
robdmau New to a Sprite, oil change questions... Spridgets 35
memphis Oil Change Austin Healey 23
B TR6 TR6 rear axle oil change Triumph 21
RJS Oil and Filter Change [how much oil?] Triumph 2
prb51 1st oil change on rebuilt motor Triumph 4
livinginthepast This may seem like a stupid oil change question... Spridgets 5
Stewart 7 quart oil change MG 4
T Oil Change, type of oil Jaguar 2
Monark192 MGB-GT 67 GT Overdrive trans oil change question. MG 6
J TR2/3/3A Oil Change in a TR3 Triumph 19
Lynn Kirkpatrick Oil Change Suckers? Restoration & Tools 12
C rear end oil change Triumph 17
W Silly question Gear Box oil change/top up MG 11
J First oil change after rebuilt and head torque Spridgets 6
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
S oil change and starting Triumph 9
J Information to Latest the Triumph Wiki -oil change Triumph 2
F TR6 TR6 oil looks dirty soon after change... Triumph 6
B TR6 TR6 Oil change Triumph 13
Wana Gearbox and differential oil change Austin Healey 8
Whytock Oil Change MG 6
J TR6 first oil change on a TR6 Triumph 1
J TR2/3/3A TR3 Oil Change Triumph 8
hondo402000 Differential Oil Change question Triumph 11
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
RSMTR8 Wedge TR8 Oil Change Triumph 9
nevets oil filter change procedure Austin Healey 22
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
PAUL161 Thanks Doc & Tony -OD & transmission oil change MG 0
A Spitfire How to change diff oil on 78 Spit? Triumph 1
S oil change Triumph 15
W TR6 How to change oil filter on a 1975 TR6 Triumph 13
