Change BE tach to electric
fordtrucks4ever
Is it doable with a later model gauge internals with faceplate and ring from BE?
mightymidget
With a drill and patience anything is possible. I liked the spitfire gauges better than the MG Midgets so I purchased a set of Triump gauges (MPH&TACH)removed mechanics from the face dail back, then placed Midget guts back in housing. So I have a Midget tach in a Triumph gauge.
Biggest thing will getting a tach small enough to fit in housing
F
fordtrucks4ever
Thanks a bunch I dont know how I have missed that whole page. It has some great info.
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
D TR2/3/3A Why it is important to change brake fluid Triumph 4
C MGA Change a pull starter to a push button system MG 6
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
T BJ8 Fan Belt Change Austin Healey 7
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
T TR4/4A Core Plug - Cam Rear change Triumph 7
B How often should you change the rear rear axle oil Austin Healey 9
G Gearbox and overdrive oil change Austin Healey 15
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
M Change LHD for MOT Other Cars 2
R Master Cylinder change working Austin Healey 12
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
davidb AH 3000 - vinyl colour change Austin Healey 7
6TTR3A TR2/3/3A Production Change Triumph 7
Michael Oritt Oil Change Problem Austin Healey 27
M MGB trying to change rotors - dumb question MG 7
C Color change...impact on Value? Austin Healey 24
JPSmit How often do you change your spark plugs? Spridgets 7
Basil Admin Note One more little change MG 1
Brinkerhoff Painting or dyeing to change interior color? Restoration & Tools 2
E Oil Change Austin Healey 1
dcoplan Spark plug and oil change question Spridgets 9
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
toysrrus What? I`ll have to change my avatar again! Triumph 13
hondo402000 Oil Change Triumph 6
Moseso A simple oil change gone South Triumph 16
J Any reason to not change the color of a Sprite? Spridgets 10
Gliderman8 Oil Change.... When to do it? Triumph 17
Marvin Gruber T-Series TD diff change & wire wheels MG 9
Anthony_S Oil Change Triumph 13
5 BN4 cylinder head casting change date? Austin Healey 5
AUSMHLY When to change oil ? Austin Healey 12
N Head Change???? MG 2
Woodie TR6 tr6 oil change Triumph 5
Rut 1275 oil change Spridgets 6
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
drooartz Time for an oil change: filter and jack stands MG 7
