First Gear Trouble BN1
Crowbar
Member
Hello all,
First gear (or second gear...due to the boxed out first gear in the BN1) has been acting up on my car.
Basically, clutch engagement has gotten very "snatchy" off the line from a full stop.
Basically, I have to release the clutch very, very slowly to engage first without chirping the tires. If I ride the clutch slightly right before completely release, the problem is minimized.
Second gear works fine, so I don't think it's a problem with the clutch. Frankly, I can start off the line in second without any trouble (due to the amount of torque in the A90 engine), so I'm suspecting a problem with the gearbox...specifically first gear.
Any thoughts? Could it still be the clutch?
Many thanks in advance.
pan
Check the mounting of the stabiliser bar that locates the transmission to the chassis. The buffer rubbers may need replacement.
Michael Oritt
I think it is the clutch. I'll leave it to someone smarter than me to explain why but it seems to take more clutch action to smoothly start off the line than to make shifts--esp. upshifts--between gears.
Having said that, because I replaced my BN1's manual clutch years ago when I traded up to a 5-speed transmission i cannot now remember the layout of the clutch and linkage, but I would suggest that you be looking there.
pan
I don't disagree with Michael, but checking the stabiliser bar is simply a matter of crawling under the car. I'd also recommend checking all the engine mounts. The rears in particular are susceptible to contamination with oil. Also check the clutch linkage. Because the 100 has a mechanical operation (as opposed to the hydraulics of the sixes) the stabiliser is required to prevent the motor from moving longitudinally when the clutch pedal is operated. With tired, soft engine mounts and an ineffective stabiliser there is little to control that movement. As the pedal is raised the clutch can take up on its own!
Good luck,
Alwyn.
DTDuck
Hello all,
It could indeed still be the clutch. When starting from a stop you have to "Slip" the clutch which is completely different than switching gears on the move which is more an in and out (insert joke here) proposition...
Could also be that starting in second gear puts more load on the clutch and makes it smoother. I would suspect that your clutch disk may be worn to the point that the rivets are digging into the flywheel or pressure plate causing the grabbing effect.
Cheers,
Dan M.
G Trouble getting flywheel ring gear on. Spridgets 23
R trouble shifting, getting into gear &stuck in gear Spridgets 22
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
Joe Reed MGB Dropping out of 3rd gear... MG 2
J Planetary Gear Removal Austin Healey 3
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
