bugeye trouble spots
clifish
I am looking for a bugeye and want to know the trouble spots I need to look into? are there any particular body/frame sections that are particularly prone to rust? Any place or people that might have some for sale particularly in the northeast? What would one expect to pay for a good driver "3 footer"?
thx
Rut
Try Craigslist, eBay, search tempest, etc...also check with Bugeyeguy.com. The main thing is to be patient! Bugeyes tend to rust in the rear quarter panels, boot floor, floor pans, spring boxes/bulkhead/shut panel, sills, A pillars, and the bottom of the doors. Rust repair and paint are probably the most expensive thing you can do on a Bugeye followed by suspension and engine work.
Rut
The rear springs boxes are the first place I check.
nomad
Agree with the above! The best thing you can do is to crawl under the car or have it put on a lift. You also will probably want an upgraded engine to a 1275 and a five speed is a plus as well. Grab the front wheels and see if their is play.
Bugeye guy always has some around but you will probably pay a premium.
Kurt
JPSmit
look under the bottom door hinge on the A-pillar - the rust may come through there instead of the outside of the car
mightymidget
Agree with door hinge inspection for rusted metal, easy to see hard for someone to doctor up, look underneath on back side of rear fenders along edge where trunk floor meets rear of car. Don'the just glance at body, stare at metal. Look for signs that bondo filler has been used to hide perforations of rust damage.
Honesty unless you know vehicle has been stripped and bad metal replaced you can figure on outer sills, lower A pillar, lower quarter extention inside and out. Floor pans. Rust free shell will be really hard to find, and come at a price, so what is on the affordable used market are Bugeyes that have been patched up and repainted.
It has not been that long ago that $5000.00 was a lot of money for nice Bugeye. So patching was no big deal.
I feel like the Bonnet is part that is most important. They are prone to rust, and repairs are expensive if you can find parts and person to make repairs. Most Bonnets for sell need work.
C what are the trouble spots on a bugeye Austin Healey 1
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
