1500 MG Midget
On a drive I had some engine trouble.
On idle the car dies and I have to pull the choke a bit to keep it running at idle (before the issues, I didn't need to do this).
I also had some smoke from the bonnet (from some oil spewing out from somewhere). Burned about 1qt of oil in 15 miles.
Pulled the spark plugs and all 4 are covered with burned oil.
I did a compression test and saw the following on both dry and wet compression tests:
cyl 1) 120 psi
2) 140
3) 90
4) 140
I also did a vacuum test and at idle I saw 15 inHg which it fluctuated about +/- 1 inHg steadly.
Unfortuatly I don't have readings on the engine before this issue came up to compare to.
Any thoughts on the issue?
cyl 1) 120 psi
2) 140
3) 90
4) 140
