AndrewMawson
Using a conventional air flow balancer or 'ear tube' is a pain on the BJ8 SU's as the air filters and hence choke mounts have to come off, and the filter bolts really need the float chamber lids off to get at. It all gets a bit tight round there!
There used to be a gizmo comprising a thin walled aluminium tube and some bent bits of wire that let you effectively measure the rise of the piston assembly in each carb and set things to get them the same.
Has anyone used this method and found it reliable and know a UK source of the kit ? (found one Stateside : https://tinyurl.com/3gexm ) If all else fails
I'll get some tube and start bending wires <g>
