I('m ready to give up. I read all these posts and nobody seems to have any real problems. I don't have any idea what to do now except get the gun and put the B (and me) out of our misery.
I have a 76B that the PO literally gutted, taking the engine primarily back to a 71 or therabouts putting on 2 AUD326 carbs (these have the spring loaded needles). I have had no luck balancing or even adjusting these carburetors at all.
A little info: carburetors were rebuilt using the standard AAE spring needle (Vicky Brit), new float chamber components (all), etc. I have a Crane electronic ignition with which I have been able to set the timing and it remains rock solid at any rpm. With a little bit of coaxing I can get the B started relatively easy but have no success in adjusting or balancing the carburetors.
I have followed the SU manuals setting the jets 2 turns down from the bridge (each jet, in fact, at .084 from bridge) and throttle adjusting (idle) screw set at 1 turn open. No matter what I do, I cannot get the idle less than 1500 rpm adjusting the jet adjusting screws or the idle adjusting.
I have been using a "carb-syn" with no luck. When placed on one carburetor and adjusted, little happens after adjustment. However, other carburetor speed increases significantly when the carb-sync is used and no amount of adjustment makes any change.
There is a monza exhaust on the car.
I have been wondering whether maybe the needles need changed (these are HS4's, by the way) but other than that I'm at wits end. Ready to admit this was a bad investment.
Help, please. I had a 72B years ago and was the greatest thing since sliced bread. /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif <font color="red"> </font>
