Zenith Carburetor
pisser
Can someone help I have two Zenith Stromberg's and they have adjusters on the bottom float bowls Do I adjust the mixture there or go through the dash pot Thank you
P
pisser
Hi All I have the two Zenith Stromberg I am trying to get them the same When i use the tester for the Idle on the front carb it kills the engine with the ball at the top No mater what I do The rear is fine It seems the slide does not come down as fast as the rear, I did loosen the linkage from each carb Even if I have the idle all the way down it will kill The lower jet I play with its so so Any ideas
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
sparkydave Zenith auto choke coming loose Spridgets 2
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
martx-5 Zenith Stromberg Carbs Triumph 4
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175cd Triumph 0
M zenith stromberg 175 cd. Triumph 7
B Question- Spridget & MGB Zenith flanges? Spridgets 2
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
Ofcalipka Zenith single carb problems MG 62
2wrench Anybody running a BP270 cam with Zenith carbs? Triumph 2
H conversion from Zenith to SU Triumph 5
M zenith float adjustment 1979 MG 1
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
H Zenith Stromberg CD 175 Too rich Triumph 7
Bret Yet another Zenith Stromberg replacement choice MG 6
jerrybny Front Zenith carb overflowing Triumph 20
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
mgbmedic Single Zenith Carb- Results MG 1
mgbmedic Single zenith carb is a joke... MG 19
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
kbash Zenith Carb. MG 3
M Zenith-Strom Carb MG 4
