Zenith Stromberg Carbs
martx-5
Over on the Miata forum, someone with a Jag XJ12 was having trouble with two carbs on one bank. Supposedly they were all just rebuilt. The symptoms were that when the engine was running, the pistons would not rise when the gas was goosed. Also, while running, it was difficult to raise the pistons manually. However, when the engine was off, he could raise the pistons with ease. The usual answers were to check the diaphragms, but the part about not being able to raise the pistons when running seemed to point in another direction. I gave him a bunch of suggestions, including that it sounded like the pistons were in backwards. I also mentioned I didn't think this was possible (as it isn't on the SUs) but told him to look anyway.
Well, it turned out that the pistons <span style="font-weight: bold">were in backwards!</span> and the car is now running fine. Is this possible with ZS carbs?
TR4
If memory serve me right, I thought the diaphragms had tabs to locate them on the pistons and tabs that locate the piston/diaphragm in the carb body so if you align the tabs where they should be, it is not possible to put them in backwards. I did read that when rebuilding carbs, you should not interchange pistons though. Maybe that is what they meant? They had the front piston and rear piston mixed up?
martx-5
martx-5
The tabs make sense. But, I mentioned the hole(s) in the bottom of the piston, and that they should be facing the back of the carb, and it turns out that they were facing the front. I guess whoever rebuilt them didn't line up the tab properly.
TR3driver
Great Pumpkin - R.I.P
That's the most likely explanation, IMO. The tab in the center is easy to overlook, if you don't know it's there. And I've even seen people get the outer tab wrong, although it's a bit more obvious.
The prohibition against mixing pistons only applies to SU carbs, because of the very close tolerance between the piston and dome. On ZS carbs, the diaphragm takes the place of the precision fit, so interchanging pistons won't hurt.
Platinum
I wonder how/if the other two were assembled correctly! I'd be lookin' at those two as well.
The slides in the domes is still of concern as to fit. I'd not mix-n-match Zed-S pistons/domes any more than I would SU's. 'specially on those lumps. 12 cylinders can hide a bunch of issues the four and six lung machines will obviously balk over.
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
77_MG_Midget Zenith Stromberg Carbs Spridgets 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175cd Triumph 0
M zenith stromberg 175 cd. Triumph 7
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
H Zenith Stromberg CD 175 Too rich Triumph 7
Bret Yet another Zenith Stromberg replacement choice MG 6
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
bluemiata90 zenith stromberg cold start adjustment Triumph 5
John75 Intro and Zenith Stromberg question Triumph 8
A Zenith-Stromberg tuning & parts MG 20
R Zenith Stromberg basic adjustment Triumph 1
7 Zenith Stromberg Question??? Triumph 6
7 Rebuilding Zenith Stromberg MG 6
Bret Zenith Stromberg 175CD vs. SU HIF44? MG 13
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
sparkydave Zenith auto choke coming loose Spridgets 2
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
B Question- Spridget & MGB Zenith flanges? Spridgets 2
Ofcalipka Zenith single carb problems MG 62
