Zenith Stromberg Running Lean
RandMeyer
When I bought my 1980 MGB, it was missing the heat shield, had some starting issues when hot and would idle inconsistently after a drive to the point of almost stalling at a light. I decided to rebuild the carb when I took it off to install the heat shield (plus it was running rich). The only problems I ran into was getting the right mixture needle. Because the engine had been replaced with one from a 1975, I wasn't sure which to use and finally figured out the 75-76 ZS carbs have four long screws and two short in the float chamber cover while the later ones have six long.
The rebuild addressed idling issues and I think the hot start issues, but it runs lean now. At least based on lifting the piston slightly and it almost stalling. Same goes for lifting the damper cap/rod slightly. I checked for vacuum leaks and found a bad one at the EGR which I fixed and still have one at the carb body to the manifold which I plan to fix.
If I adjust the needle all the way rich, it still runs lean. Can the vacuum leak be the cause? The EGR valve leak had to be there before. I pulled the plugs tonight and based on the photos on theautoist.com I'm a #2 (gray with a slight pink tint). I also feel a hesitation at times, not really a skip due to a plug not firing.
Thanks for your advice.
JPSmit
I suspect the leak might be the cause as ZS's almost always run rich - fix the leak first for sure - then check
Platinum
Yup. A vacuum leak will lean out the mix. You'll need to fix all that before you can get a good setting with the carb.
R
RandMeyer
Thanks guys. I'll pull the carb and try to better address the vacuum leak. I used new gaskets and used some gasket dressing without success. I'll try applying more next time and see if I can achieve success. I thought I would see some improvement with the EGR vacuum being fixed, but I guess not.
Platinum
Try locating Permatex Hylomar for the gasket. A THIN film should do.
Rumor has it Harbor Freight carries it.
R
RandMeyer
I pulled the carb and figured out the gasket between the heat shield and the induction heater was oriented incorrectly. I had the narrow part to the top/bottom and the contact for the heater was outside the gasket. I reoriented it and put everything back together. No leak confirmed with carb cleaner.
It is still running lean based on the lift the piston test and I can't find any other vacuum leaks. However, I have figured out the anti run-on valve is not working. Could that be contributing to the lean running?
bob67bgt
Maybe put the old needle back in and see what happens? Are you sure the needle is moving when you turn the adjusting allen screw? Can you tell any difference when you adjust the mixture? Also if you changed your air filter at the same time as the rebuild that could be the reason it appears lean now. The filters get dirty from the inside and may have been restricting airflow. If its not spitting back thru the carb when warm (under load) i would think you are fairly close. Just some things to check and maybe get you on track to fix it! Bob
R
RandMeyer
The needle is definitely moving when adjusted based on pulling the piston and resetting it to flush with the piston a couple of times. The air filter was changed back in February prior to any of this and still looks clean.
I pulled the anti run-on valve last night and found it full of charcoal. Once I cleaned it out it seams to be working, but I'm now trying to get the charcoal cannister out so I can rebuild it and prevent the reoccurrence of the blockage.
I have not tried running it since I pulled the anti run-on valve, but I wonder if the valve was jammed partially open it could be causing issues?
If this doesn't help, I'll try the old needle.
Thanks again for the advice.
Rand
R Zenith Stromberg Running Lean - Up-date MG 1
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Zenith stromberg carbs Jaguar 3
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
martx-5 Zenith Stromberg Carbs Triumph 4
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175cd Triumph 0
M zenith stromberg 175 cd. Triumph 7
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
H Zenith Stromberg CD 175 Too rich Triumph 7
Bret Yet another Zenith Stromberg replacement choice MG 6
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
bluemiata90 zenith stromberg cold start adjustment Triumph 5
John75 Intro and Zenith Stromberg question Triumph 8
A Zenith-Stromberg tuning & parts MG 20
77_MG_Midget Zenith Stromberg Carbs Spridgets 6
R Zenith Stromberg basic adjustment Triumph 1
7 Zenith Stromberg Question??? Triumph 6
7 Rebuilding Zenith Stromberg MG 6
Bret Zenith Stromberg 175CD vs. SU HIF44? MG 13
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
sparkydave Zenith auto choke coming loose Spridgets 2
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
B Question- Spridget & MGB Zenith flanges? Spridgets 2
Ofcalipka Zenith single carb problems MG 62
