"ACK!!! The oil tube should be swedged in the piston, the dowel should fit inside the tube to only drive out the needle assembly! I ~assumed~ you had an illustration (VB or Moss catalog at the least) to view, so-as to see the exploded view of the needle assembly -inside- the tube... never gave a THOUGHT to driving the tube out of the piston. <STUNNED!>"
Dr E.
I know it seems unlikely but I was whacking on the needle assembly and I do have pictures. Shortly, I will use the torch and either melt it or get it apart. Yes, it is actually very clean. I suspect it was either super glued or secured with loctite red. When I rebuilt the carbs last week, I could not get the needles out of the vacuum valves.
I wondered why someone would spend so much money on a project only to abandon it. Now I know!
Thanks and have a nice day
Steve
