Question- Spridget & MGB Zenith flanges?
Billm
As the title says- does a Midget Zenith carb and an MGB Zenith carb have the same mounting bolt spacing? I am thinking about putting an HS4 on a friend's '79 MGB and don't have an MGB manifold to measure (here).
Bill
JPSmit
Not sure about the B but the ZS and the HS4 do not have the same bolt spacing - but it is only 20 minutes to adapt the HS4 with a file
RichBall
Bill
Most likly not as the Midget ZS has a 1.5 inch throat and the MGB ZS has an 1.75 inch Throat. Also, the Midget ZS is held by two studs while I belive the MGB uses four studs.
JPSmit Spridget thread question FORUM Navigation Questions 2
T Question regars 'frame assembly-hood' for various spridget models Spridgets 7
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
anarchy99 Hardtop question... Spridget related Spridgets 21
RickB Not Spridget, but Evil Mini-Van question Spridgets 14
C Spridget Body/Chassis Structure Question Spridgets 13
B General Spridget Driving Question Spridgets 18
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
