Zenith stromberg carbs
wrenchranch
Has anyone tried to fit the "Grose Jet" valve into a Z-Stromberg carb? I find I cannot get it to screw in completely and therfore the gasket does not seal. It appears the threads are slightly different than the bore threads and the stock needle and seat.
Greg in Montana
LarryK
I tried the "Grose jet" on my Series 1 XJ6, thought this would be cool and never have problems. Replaced and drove car to work, upon leaving at night found a trail of fuel 30' long coming from car. Called wife and had her bring old jets and put back in and never had a problem again.
jessebogan
If I remember correctly (always an issue) grose jets for strombergs came with a selection of gaskets, and I remember using a couple on each one.If that is not the case, contact them, perhaps they have an explanation or work around. Otherwise the stock needle and seat assemblies work fine. Oh yeah, one last thought. Strombergs originally have a small screen that kinda fits to the needle and seat assy. When the N and S get changed over the years, sometimes I have seen them stuck in the fuel inlet above the NandS assy. Check and see as that might prevent the grose jet from going in far enough.
Platinum
More bother than they're worth, IMO. A Viton tipped N&S are about as "trick" as is necessary.
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
L zenith-stromberg carbs Lotus 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
martx-5 Zenith Stromberg Carbs Triumph 4
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
77_MG_Midget Zenith Stromberg Carbs Spridgets 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
bfitz Zenith Stromberg O ring question Other British Cars 8
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
R Zenith Stromberg CD 175 float replacements? Triumph 3
eschneider TR4/4A TR4 Zenith-Stromberg CD175 tuning question Triumph 4
M zenith stromberg? Triumph 1
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175cd Triumph 0
M zenith stromberg 175 cd. Triumph 7
R Zenith Stromberg Running Lean - Up-date MG 1
R Zenith Stromberg Running Lean MG 7
I Zenith stromberg metering needle removal help Triumph 9
I zenith stromberg float brass plug removal help Triumph 14
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
J Zenith Stromberg question MG 4
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
H Zenith Stromberg CD 175 Too rich Triumph 7
Bret Yet another Zenith Stromberg replacement choice MG 6
S Zenith Stromberg Mixture Adjuster Restoration & Tools 13
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
bluemiata90 zenith stromberg cold start adjustment Triumph 5
John75 Intro and Zenith Stromberg question Triumph 8
A Zenith-Stromberg tuning & parts MG 20
R Zenith Stromberg basic adjustment Triumph 1
7 Zenith Stromberg Question??? Triumph 6
7 Rebuilding Zenith Stromberg MG 6
Bret Zenith Stromberg 175CD vs. SU HIF44? MG 13
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
Celtic 77 MGB Tinny Zenith air regulator MG 0
P Zenith Carburetor Triumph 2
P MGB Zenith water choke gasket needed MG 4
P MGB Zenith 175 cd carb damper oil MG 2
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
sparkydave Zenith auto choke coming loose Spridgets 2
C TR6 Zenith Strombers won't start when warm. Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 3
A Zenith 175 CD's Triumph 19
A Zenith 175CD carbs Triumph 9
CZ_Dave Zenith Carb MG 13
B Question- Spridget & MGB Zenith flanges? Spridgets 2
Ofcalipka Zenith single carb problems MG 62
