TR2/3/3A Drive shaft question
Linoman
This fall I'm planning on switching out the non-syncro nonoverdrive tranny for a TR4 full syncro with overdrive. Will I need a different drive shaft?
~Tim
charleyf
The answer is no. The drive shaft has a sliding spline that allows it to move forward and back in length.
But you will need to modify the rear tranny mount. You will need to elongate the two bolt holes to the rear by about 5/8". You may also need to grind off a bit of the raised portion at the rear of this plate if it interferes with the tranny.
L
Linoman
Thanks Charleyf, wanted make sure I wasn't going to need anything major beyond the tranny, wiring, switch, and solenoid.
I'm looking forward to this upgrade, every time my wife or I are out for a drive we find ourselves trying to find 5th gear. :smile:
CJD
If you’re current tranny is an early model, you may need a different flywheel, starter, and tunnel cover.
charleyf
Your profile shows a 1960 TR3. So I would guess that you have a commission number car after TS50000. That should mean that if your car is stock your flywheel,clutch and starter are all compatible with the TR4 tranny. You will likely enjoy both the full synchro and overdrive.
Geo Hahn
You will, of course, need to swap your TR3 gearshift lever over to the TR4 gearbox.
In case you do not know, there are a couple of additions that some (me) feel are a good idea here. Adding a diode to make life easier for the relay and adding a fuse (I used a slo-blo) to protect the wiring should the the solenoid pull-in circuit fail to release. Several threads here on both - credit for both ideas goes to our late friend Randall.
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
W Drive shaft question Spridgets 8
T Question on Serviceability of Drive Shaft Componen MG 2
mountainman TR 3 Drive Shaft Question Triumph 6
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
R TR6 Drive shaft orientation Triumph 3
C Bugeye propeller/drive shaft- universal joint Spridgets 1
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
R TR2/3/3A Maintenance on Drive Shaft Triumph 18
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
PAUL161 T-Series Balancing Drive Shaft MG 4
Gliderman8 TR6 One piece drive shaft? Triumph 6
B TR2/3/3A Transmission / drive shaft knock ?? Triumph 16
R Drive shaft universal joint bear cap modification Austin Healey 7
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
S How much grease for the drive [prop] shaft plunger Austin Healey 3
S TR2/3/3A Distributor drive shaft play Triumph 4
S TR2/3/3A distributor drive shaft gear Triumph 4
CJD TR2/3/3A Overdrive Drive Shaft Triumph 4
B Spitfire How do you replace U Joint on late model Spitfire OD Prop/Drive shaft? Triumph 7
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
D Paint the drive shaft... Spridgets 6
J TR6 TR-6 Drive Shaft Removal ? Triumph 4
B Overdrive drive shaft? MG 8
AEW what is the short drive shaft? Triumph 5
pjsmetana New Lugnuts? Drive shaft Play? Triumph 7
MGTF1250Dave TR2/3/3A TR3 Drive Shaft Grease nipple Triumph 4
A Drive Shaft plat at differential MG 2
drooartz Which drive shaft? Spridgets 13
P Drive shaft won't come out of the transmission Spridgets 6
jhorton3 Drive Shaft Spridgets 0
N TR6 Bolt size for TR6 Drive shaft? Triumph 6
ronzet MGA Late MGA 1500 Drive shaft dust cover MG 0
prb51 TR2/3/3A TR3 drive shaft flange issue Triumph 1
G How do I separate my drive shaft to lube splines Triumph 4
B TR6 TR6 Drive Shaft Cover Triumph 7
D drive shaft/rotor alignment British Motor Corp 3
guzzul Drive Shaft Balance Triumph 8
jlaird I need a drive shaft, Tony or anyone. Spridgets 9
H Towing 62BT7 with Drive Shaft Connected Austin Healey 4
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
B Drive Shaft Austin Healey 12
D Used Drive Shaft Coupling Needed British Motor Corp 0
D Unequal Drive Shaft Lengths British Motor Corp 3
T Mini drive shaft nut size. British Motor Corp 2
svtmikey Getting the hub off the drive shaft Triumph 3
M TR2/3/3A HVDA Speedometer Drive Triumph 10
