Transmission rear bush for drive shaft yoke - no joke!
BusterB
Hello Everyone,
I am new to this forum, and need some help, please.
I purchased a 69 Sprite recently and had some gearbox issues.
So I took the gearbox out for a 'quick' re-build.
Everything is fine apart from the rear bushing where the propshaft yoke is located.
There was some play in the old one so I thought I should replace it (big mistake).
And had my local machine shop ream the new bush to fit the yoke.
Then once the gearbox output shaft was in place the yoke no longer fitted.
And I could see that the output shaft was a few '000 off center.
Is this a common problem?
Moss Motors tell me they sell loads of these bushes and never have any problems!
So I need some help please.
My machine shop is ready to measure the offset and use a boring tool to ream a new bush out 'off-center' to make this work, but that will be several hours work and its not cheap.
Just before I give the go-ahead to this exercise, I though I should ask you guys if I'm missing something!!
Thanks
Administrator
Boss
Hi Buster and welcome to the forum! You posted your question in our :Forum Help" which is a forum for asking questions about how to navigate this forum, etc. Since you are asking a question about a specific car type, I am moving your post to our "Spridgets" forum. I will leave a "marker" post here in the Forum Help forum for a while, but your actual post is now residing in the Spridgets forum.
T Looking for "BillMs rear transmission mount" Spridgets 2
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
R J-H rear transmission seal? Why can't I find it on the web? Other British Cars 1
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
Bob Claffie MGB Transmission rear seal MG 8
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
JPSmit Rear - Transmission seal question Spridgets 8
R transmission and rear end oil Austin Healey 2
J TR 4 Rear Transmission Counterweight Triumph 8
Bruce_B %#@#%@ 5 speed transmission - rear mount!!--Help Spridgets 11
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
ronzet MGA MGA rear transmission mount MG 12
cdsmith Transmission oil? Rear end oil? Spridgets 15
C Speedo calibration vs rear end or transmission Austin Healey 13
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
