transmission and rear end oil
bighealeysource
Bronze
I use non detergent 30 weight in my '56 100M trans and 90 wt in the rear end. Do not know if that is the proper recommendation for a later BJ7 but sure you will get good feed back from others.
Regards,
Mike
Keith_M
I use exactly the same in my 62 BT7. There's something about the non-detergent part that's important for the tranny and overdrive, and 90W is pretty standard for the rear end.
Keith
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
cdsmith Transmission oil? Rear end oil? Spridgets 15
C Speedo calibration vs rear end or transmission Austin Healey 13
T Looking for "BillMs rear transmission mount" Spridgets 2
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
R J-H rear transmission seal? Why can't I find it on the web? Other British Cars 1
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
Bob Claffie MGB Transmission rear seal MG 8
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
JPSmit Rear - Transmission seal question Spridgets 8
J TR 4 Rear Transmission Counterweight Triumph 8
Bruce_B %#@#%@ 5 speed transmission - rear mount!!--Help Spridgets 11
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
ronzet MGA MGA rear transmission mount MG 12
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
