TR 4 Rear Transmission Counterweight
jimitro
Hi,
I found a Rear Transmission Counterweight(looks like hanging weight with a clamp above it) in my parts box that may have been originally installed on my TR4 that was not put back on. Is this necessary or useful to re-attach?
Or was this only on TR3s?
Thanks
TR3driver
Great Pumpkin - R.I.P
If the rubber insert is in good shape, it might be worth installing. It was supposed to reduce gearshift vibration at certain speeds; and AFAIK only used on some TR4s. TR3s have a shorter lever and hence less trouble with it vibrating.
JerryVV
TR4nut said:
JerryVV said:
Sounds like a potential VTR event: the 10 lb counterweight hurl :smile:
That's a good use for the darn things. I keep putting mine back on the car but I really wonder why I do it. I hope to never be back into my car in that area agin but if I am it will come off.
J
jimitro
Thanks for the recommendations/comments.
I think I will use it as a canoe anchor and now probably get another 2miles per gallon!
Cheers
bgbassplyr
I bought a wrecked parts TR4A w/od that had this weight, so they were still being used in '66, FWIW.
HerronScott
Had one on my TR4A as well.
It's part number 144314 for non-overdrive and 132604 for overdrive in the TR4A SPC - Weight and bush assembly, vibration damper! :smile:
Scott
nissanite
I think if Triumph could have saved that money to lower the vehicle price or used it for Gross Profit they would have.
I will take it if it is still rubber & not solid
T Looking for "BillMs rear transmission mount" Spridgets 2
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
R J-H rear transmission seal? Why can't I find it on the web? Other British Cars 1
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
Bob Claffie MGB Transmission rear seal MG 8
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
JPSmit Rear - Transmission seal question Spridgets 8
R transmission and rear end oil Austin Healey 2
Bruce_B %#@#%@ 5 speed transmission - rear mount!!--Help Spridgets 11
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
ronzet MGA MGA rear transmission mount MG 12
cdsmith Transmission oil? Rear end oil? Spridgets 15
C Speedo calibration vs rear end or transmission Austin Healey 13
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
