Transmission oil? Rear end oil?
cdsmith
Okay … The car went on its second road trip (another 1 tenth of a mile – no license or insurance, so the best I can do is a quick run up and down the street).
Now I’m thinking about changing transmission and rear end fluids. So here is the question: What kind of oil should be used in transmission and rear end? I've read that I should use motor oil (at least in the transmission), but nothing specific about what type, weight, whether or not it should be multi viscosity, and so on…
So… anyone out there willing to go out on a limb and make a definitive statement on this subject?
I do appreciate the help…
cd
Tom Rynne
20/50W motor oil in the tranny
90W gear lube in the differential
spritenut
I agree with Tom.
20/50 tranny
90 or 90/140 in the diff.
Stay away from synthetics in the tranny.
Something about synthetic oil that attacks the brass (or bronze) parts in the gearbox.
Frank
sparkydave
Depending on what year yours is, it may take SAE 90 oil for the transmission. The ones from '75-'79 did, but I'm pretty sure the Haynes book said all the spridgets took 90 weight in the trnasmission and differential.
-Dave
77MidgetMkIV
Sparky- so are you running the SAE 90 in your tranny? I am loking to do mine whilest it is on stilts for the brakes, and originally was going for the 20w50, but your comment on the 75-79 caught my eye, as I have a '77.
thx
sparkydave
Hi Mark, I've got SAE 90 gear oil in both the rear end and transmission. Supposedly the MGB calls for 20W-50 in its transmission, but my original owner's manual, the Haynes manual, and the MG Factory Workshop manual all call for SAE 90 in the Midget. BTW, if you need something to remove the fill and drain from the rear end, I made one from a 3/8" to 1/2" drive socket adapter. I just used a Dremel to grind the edges of the 1/2" end and it works nicely.
-Dave
77MidgetMkIV
Good to know! The wife is off on a girl's weekend this weekend, so I am stocking up everything for a couple days in the garage, so I will be picking up the oil today.
thx
dklawson
I've never heard of synthetics attacking anything in a gearbox. My understanding is that the additional friction protection normally attributed to synthetics makes them unsuitable for gearboxes as they reduce the effectiveness of the synchros (which must work by friction). Regardless, don't run synthetic in your gearbox.
Early Minis like mine share some gearbox parts with the rib case transmission Spridgets. Minis use 20W50 but we have to change it very frequently since they use the same oil for the gearbox, engine, AND the final-drive (differential) unit.
77MidgetMkIV
Yeah. I have gotten all the warnings on synthetic in the tranny, and if memory serves, there is a thread here somewhere regarding synchro functionality and synthetics.
aeronca65t
All 1500 cars run gear oil in the trans (typically 90 weight or so). This is the Spitfire/Marina all-syncro trans.
1275 and earlier cars (with the "ribcase" and "smoothcase" tansmissions) use motor oil (20W-50 works nicely).
As for sythetics, I do not use them in the engine but have had excellent results with Mobil 1 sythetic gear oil (and also Red Line gear oil) in the trans of my 1500 racer. When I switched from regular gear oil to sythetic, the trans shifted much faster and smoother. Every other Spridget I race with, also uses sythetics (they are all 1275 cars and use sythetic motor oil).
I'm using sythetic gear oil in the final drive also.....Sprite rears tend to be a bit more leaky than other cars, but the sythetic actually seems better in my car (hasn't lost a drop so far).
That's my experience anyway.
Matthew E. Herd
I'm just running generic hypoid gear oil in the diff and it leaks a bit (looks like I'll be rebuilding the rear axle soon, so I'll take care of that now). However, I definitely second Nial's comment about using synthetic gear oil. I replaced generic 75W90 hypoid oil which was blowing out of the trans with the Redline Synthetic offered by Moss. The stuff is wonderful! Shifts are faster and smoother, with generally a better feel. I also thought that I was losing trans oil, but discovered upon attempting to fill it that it was actually at the same level as it had been when I last filled it with Redline. I guess that means my rear main seal is leaking a bit ... hard to say. At any rate, using synthetic transmission oil in your 1500 is a good idea. I can't really speak for the older A series transmissions that take motor oil.
Matt
77MidgetMkIV
Well, this puts a new spin on it. I run synthetic in the engine, and it has been great. Aeronca and Matt- you have my interest perked on the synth. gear oil for my tranny. Are you of the opinion, then, that the cautionary tales regarding potential damage to the tranny's innards from synth. oil are off base?
aeronca65t
I'm basing my comments on my experience and I note that others I race with also seem to like syn-oils in tranmissions and final drives.
I'm not a chemist so I do not claim any technical analysis on the subject.
I am a mechanical engineer and I have noted no extreme tranmission wear (other than the normal wear-and-tear of racing).
Red Line has a bunch of tech-papers on line and they claim that their products do not void any warrantees. Here's a lnk:
https://www.redlineoil.com/tech.asp
77MidgetMkIV
Thanks for the input. At this point, I think I am leaning toward synth. gear oil. I also use Mobil 1 products, in my other vehicles and equipment, and am happy with it, so I will stay with that if I go this route.
Matthew E. Herd
Ditto about being a mechanical engineer ... except I'm just finishing my bachelors. /ubbthreads/images/graemlins/smile.gif Nial's done quite a bit more studying than I. All I can say is that moss recommends it and I think it works well in terms of shifting feel. If it's eating my synchros, at least it drives well at present! However, I'd bet that since it drives well, it probably isn't causing them to deteriorate. The same synthetic oil has been sitting in my transmission since last august and I've noticed no problems from the synchro standpoint (I had hydraulic issues, but they are unrelated).
R transmission and rear end oil Austin Healey 2
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
EWD TR6 Transmission Oil Seal Triumph 13
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
TomMull TR2/3/3A Transmission oil leak Triumph 17
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
vette Transmission Oil Austin Healey 5
M What is the proper oil for Bugeye engne and transmission Spridgets 6
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
T Transmission Oil Austin Healey 7
P TR2/3/3A TR3 Transmission oil Triumph 13
bobh Changing Transmission Oil in 10 minutes Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
T 1275 transmission oil leak Spridgets 2
M Transmission oil Spridgets 2
Jim_Gruber Transmission Oil and Differential Spridgets 3
J location of transmission oil filler on a BN-2 Austin Healey 5
PAUL161 Transmission oil Type MG 3
ekamm TR2/3/3A tr3a transmission oil preferences? Triumph 4
TRnorwegian Easiest way to check refill oil in transmission? Triumph 20
AUSMHLY Another transmission oil question Austin Healey 19
66healey oil for transmission Austin Healey 2
dklawson Transmission Gear Oil - Synthetic? Triumph 7
Stewart Leaky transmission oil drain plug MG 3
R Best gear oil for transmission in midget[snail] Spridgets 3
R 1500 with OD transmission oil recommendations Triumph 15
martyc MGB MGB Transmission Oil -- with Tasty Metal Shavings MG 2
ronzet Transmission Oil Recommendations Austin Healey 8
M Transmission Oil Spridgets 13
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
G Changing front oil seal on transmission. Triumph 14
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
ronzet Oil Viscosity Transmission Austin Healey 17
nevets transmission/OD oil question Austin Healey 17
PAUL161 Thanks Doc & Tony -OD & transmission oil change MG 0
T How full to refill transmission oil? Spridgets 4
gbtr6 Transmission Oil/Lube Triumph 4
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
B transmission oil?? MG 10
S TR2/3/3A Tr3 transmission oil Triumph 4
Johnny Transmission oil seals Austin Healey 8
Michael Oritt Transmission oil specification--Toyota box Austin Healey 10
S Transmission oil filler where is it? MG 5
R transmission oil Austin Healey 4
G Transmission oil dilemma Triumph 6
D Transmission oil pump question MG 2
7 Transmission Oil Refil MG 3
