TR2/3/3A What weight transmission oil in a tr3 with OD?
sp53
What weight transmission oil in a tr3 with OD? I have been spoking around the internet for ½ hour and I am still not sure if it is 30 non detergent or GL4. I have always run 30 weight non detergents in my tr3s for more than 40 years—but I will say they have leaked and made noise. Now with this OD I am concerned. It sounds like both would be fine, but 30w is conservative way to go. I just see a huge difference between 90w+ and 30 weights.
TFB
I have been running Redline MT-90 based on recommendations from this site and am happy with it.
12.5k mile and no problems.
tom
TR3driver
Great Pumpkin - R.I.P
Triumph changed their specification around 1958-59, from motor oil to gear oil. Supposedly to make the countershaft bearings in the main gearbox live longer.
If your car is earlier than that, then I can see some justification to using motor oil; otherwise it makes no sense to me.
BTW, 90 weight and 30 weight aren't as far apart as you might think. Motor oil and gear oil are deliberately graded on different scales, so the number tells you what oil you're talking about. 90 weight gear oil is actually about the same as 50 weight motor oil (which is what Triumph recommended in warm climates, before they started recommending gear oil).
FWIW, I really like Redline's MT-90 in the gearbox. Rated GL4 (so meets that spec), but produces noticeably better shifting in the main box, both hot and cold, compared to ordinary GL4. Kind of expensive, but worth it IMO.
Andrew Mace
Yeah, it is "kind of expensive"; on the other hand, I'll second Randall's comments about noticeably better shifting (in a Herald/Spitfire box, in my case). Also, if your car is anything beyond a $700 "beater," "expensive" is very much a relative term, right? :D
CJD
Hey Steve...I went with the factory recommended straight 30w initially, but had issues with the OD drum sticking. The Redline MT90 fixed that immediately, so that's what I have been using since.
ckeithjordan
Does the gear box with OD take I quart or a little more of the red line MT 90?
The specs page of the owners manual says a gearbox with OD takes 3.3 pints (52.8 ounces) or a little over a quart and a half. That's for a drain and refill. If dry, the amount is 4.2 pints/67.2 ounces/2.1 quarts.
S
sp53
Thanks for accurate answer Keith. Those manuals confuse me because there are/maybe was imperial pints and stuff like that. Well at least that is how I remember translating some of the stuff.
ckeithjordan
You're welcome. There are two columns on the page, one for Imperial measurements, and one for us. You just have to make sure you're reading the right one. I copied the info down and posted it on my garage wall above my workbench so I wouldn't get confused (also, because I can't remember the quantities to begin with!).
S
sp53
Ok it looks like the MT redline 90 is a 75 to 90W synthetic. I did find one quart in town for 17.00 and they are ordering more. Plus I have some 75- 90w Valvoline, but is says limited slip on the bottle. I read how limited slip will effect the operation for the OD in negative way. Is that true?
TR3driver
If you're looking at the synthetic stuff, it's too slick for good synchro operation.
Works good in rear axles, though.
S
sp53
I am thinking to put the Valvoline 75- 90 w limited slip gear oil in because heck I might be pulling the gearbox if will not go in and out OD well, but did not want to create a problem. I was about to put the Valvoline in and then read some posts from 2012 that said do not use poly weight and non-splip because something in the OD did not like it. Paying for these educations in life requires advice and hands on. My gut tells me put the Valvoline in; it is not that big of deal?
Herk
So read the back label, if it says "yellow metal safe" it won't erode the synchros and bushings. But if it's a synthetic you want, you'll be much happier with "synchromesh" or "MTL" or "MTF" labeled fluids. They have a friction modifier package formulated for synchronizers. I made the error of filling my TR6 with 75-90 synthetic gear oil once. The overdrive worked just fine, but it shifted like a cold truck. I filled with Valvoline MTF and never looked back. In fact my dad, who's racked up over 200K with motor oil in his TR3A overdrive box (changed annually) noticed an improvement with the MTF.
Tybalt
Herk has pretty much called it when it comes to making sure that you use something that is aimed at transmissions and not differentials. The fact that it says limited slip tells me that it is primarily intended for differentials and not transmissions. The additive package in the extreme pressure gear oils has a tendency to play havoc with synchronizers. Even Valvoline on the product information sheet for the 75w-90 gear oil to use their transmission specific oils in synchronized manual transmissions.
Here are links to the Valvoline Product Information Sheet for their GL-4/GL-5 EP Gear Oil:
https://sharena21.springcm.com/Publ...2d889bd3/cf662252-0bbd-e711-9c12-ac162d889bd1
speaking of "not creating a problem," here's a nice little primer on GL-4 vs GL-5, some gear oil history and the havoc that GL-5 can play with synchronizers, it was aimed at the Corviar world but it applies to others as well:
https://www.widman.biz/uploads/Transaxle_oil.pdf
Transmission lubricants have been a big topic of discussion in the Miata and S2000 world as well as in the British Car universe so you can get some reasonable information related to the topic from those types of forums plus there's always Bob is the Oil Guy ( https://www.bobistheoilguy.com/ ).
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
Luke_Healey 80/90 weight in the transmission? Spridgets 18
W Weight of engine and transmission Spridgets 8
A Weight of Engine and Transmission Spridgets 1
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
Michael Oritt 100 Flywheel Weight Austin Healey 16
T TR2/3/3A Body Tub Weight Triumph 8
X Technical specifications including the maximum technical weight TVR 8
H MGA MGA engine weight? MG 3
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
R Engine component weight reduction Austin Healey 53
BoyRacer weight of bare Healey chassis Austin Healey 8
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
kennypinkerton MGB Body shell weight? MG 3
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
BOBBYR Frame weight Austin Healey 14
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
glemon General TR Weight Loss Program Triumph 9
GeorgeC Hardtop weight? Spridgets 6
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R weight of BJ8 Frame with inner body panels Austin Healey 1
P 1275 Weight?? Spridgets 3
D Engine weight Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
5 TR2/3/3A TR3 bare shell weight Triumph 9
G RB weight sans driveline and bumpers? Spridgets 5
T Weight difference beween steel and wire rims Triumph 11
S Weight of Bugeye unibody Spridgets 2
M 3.0 iron weight difference Austin Healey 7
J Another pic of the E-Type light weight Jaguar 0
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
A Rear end weight? Austin Healey 7
J TR2/3/3A TR3 tub weight? Triumph 16
B Engine Oil Type and Weight? Austin Healey 8
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
hilsideser Spitfire Spitfire frame weight? Triumph 6
B Rear Clip weight Triumph 2
Ken40 MGB-GT MGB/GT body shell weight MG 3
B Race spridget weight jacking Racing 8
aeronca65t Corner weight setup Racing 3
K Curb weight Triumph 4
BionicHealey Chassis Weight Austin Healey 13
PatGalvin TR2/3/3A TR3 Flywheel Weight Triumph 9
B piston/rod assembly weight Austin Healey 0
B Need for piston/ rod assembly weight Austin Healey 4
vette Engine Weight Austin Healey 19
