weight of BJ8 Frame with inner body panels
robolab
I will carry the bare frame with mounted inner body panels on a trayler to the sandblasting shop. Wath´s the weight of the parts together, or how many worker are necessary to put it on the trailer.
Healey Nut
Easiest way to pick it up is with two long lengths of wood 2x6 would work . . put them underneath the car front and rear under the engine bay and near the rear outriggers . Four in shape adults can then pick the frame and body up reasonably easily . Hopefully the body panels dont have 3/8" of bondo on them that will make it really heavy .
I BJ8 Drivetrain Weight? Austin Healey 1
Michael Oritt 100 Flywheel Weight Austin Healey 16
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T TR2/3/3A Body Tub Weight Triumph 8
X Technical specifications including the maximum technical weight TVR 8
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
H MGA MGA engine weight? MG 3
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
R Engine component weight reduction Austin Healey 53
BoyRacer weight of bare Healey chassis Austin Healey 8
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
kennypinkerton MGB Body shell weight? MG 3
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
BOBBYR Frame weight Austin Healey 14
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
glemon General TR Weight Loss Program Triumph 9
GeorgeC Hardtop weight? Spridgets 6
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
P 1275 Weight?? Spridgets 3
D Engine weight Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
5 TR2/3/3A TR3 bare shell weight Triumph 9
G RB weight sans driveline and bumpers? Spridgets 5
T Weight difference beween steel and wire rims Triumph 11
S Weight of Bugeye unibody Spridgets 2
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M 3.0 iron weight difference Austin Healey 7
J Another pic of the E-Type light weight Jaguar 0
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
A Rear end weight? Austin Healey 7
J TR2/3/3A TR3 tub weight? Triumph 16
B Engine Oil Type and Weight? Austin Healey 8
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
hilsideser Spitfire Spitfire frame weight? Triumph 6
B Rear Clip weight Triumph 2
Ken40 MGB-GT MGB/GT body shell weight MG 3
B Race spridget weight jacking Racing 8
aeronca65t Corner weight setup Racing 3
K Curb weight Triumph 4
BionicHealey Chassis Weight Austin Healey 13
PatGalvin TR2/3/3A TR3 Flywheel Weight Triumph 9
B piston/rod assembly weight Austin Healey 0
B Need for piston/ rod assembly weight Austin Healey 4
vette Engine Weight Austin Healey 19
healeyboz flywheel weight Spridgets 2
T Is the Patton aluminum crank hub enough weight? Triumph 21
rick_ingram MGC Weight of MGC MG 21
