How full to refill transmission oil?
tdskip
Hi folks - quick question. I just drained the Bugeye's transmission oil and I can't find reference info on how full I need to refill her.
I believe it is to the bottom of the filler plug, but want to double check before I actually do it.
She is a 1960 with a ribbed case.
Haynes guide is of no use here - I did check before asking!
GB1
I forget the exact amount right now, 1 qt something(I think 1/4). Or just below the filler hole. Lets see what other say, it has been a while for me.
Bugeye58
Skip, from empty, the ribcase takes 2.7 pints, or about a quart and a half, of the same oil you use in the engine.
Oh. and get a Bentley book.
Jeff
T
tdskip
Thanks guys - Bentley book is on order but didn't arrive yet and I wanted to get cracking.
As usual - thanks a bunch and for being patient with me while I learn!
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
L MGB 1977 MGB will only run on full choke MG 53
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Editor_Reid 2011 Aston Martin V8 Vantage N420 Goes Full Lockdown Other British Cars 54
jackq Another building full of cars available. Other Cars 0
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
jackq General MG Got a room full of MGs MG 11
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
M For Sale Aston Martin wheels for Sale - $1600 - Full set in the original boxes Other British Classifieds 1
sim fuel tank sender reading full all the time Spridgets 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
NullReturned Full Service Advise for '68 Sprite MKIV Spridgets 7
C Full tank but no fuel!!!!! Austin Healey 15
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Boggsy64 MGB Full strip for paint MG 3
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
Jim_Gruber Castrol GTLMA - Full Synthetic Spridgets 4
P fuel gauge always full Austin Healey 2
NikolausConrad Spitfire Spitfire full syncro gearbox build Triumph 3
N BJ8 out of fuel at 1/4 full tank Austin Healey 4
B Restore a rusty uni body car vs a full frame car? Restoration & Tools 4
T Bought a full sized electric oven for .99c on eBay Spridgets 7
PeterK Castrol Edge full synthetic Triumph 2
S TR2/3/3A Full spats for a TR3? Triumph 11
GBRandy TR2/3/3A Is this TR3 Rocker Panel Full of Putty? Triumph 11
livinginthepast 62 Sprite Fuel Gauge always on Full - Spridgets 9
novashawn Swap my full sun roof for Austin S wheels ? British Motor Corp 0
H Storage unit full of Spridget parts Spridgets 35
jbowlby Missing at full temp Spridgets 11
M Full of [3] Questions Spridgets 9
BobbyD Warehouse Full of NOS Parts Triumph 6
R TR2/3/3A TR3 full circle Triumph 12
Brosky Cam bearings, full disclosure with pictures Triumph 10
StagByTriumph STTAG Restoration Team pulls the FULL MONTY! Triumph 7
T How to tell if you need bearings or full rebuild Triumph 19
T TR2/3/3A TR3A gas gauge stuck in "Full" Triumph 26
YankeeTR British Car Field Day, Sussex, WI...A full report Triumph 5
jhorton3 Full Interior Kits Spridgets 2
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
Randy Harris Brake fluid canister - how full? Austin Healey 5
G Any suggestions for draining a full gas tank.... Triumph 24
Baz Full day of work Spridgets 35
boxofparts MGB 79 MGB tach needle swings about full scale at 3500 MG 5
jlaird Life is just full of little joys Spridgets 7
