Brake fluid canister - how full?
Randy Harris
Good morning all. Ever since I had my clutch slave replaced the fluid cannister has been leaking. I suspect my mechanic overfilled it after bleeding. Is there an ideal fill level?
Thanks
Randy
'66 BJ8
shorn
After replacing both my brake and clutch MC's, I found that my reservoir was also leaking onto my freshly painted engine bay. It took awhile to determine that the leak was from the bottom of the reservoir by the connection for the line to the brake MC. Apparently in removing the MC's I had moved the lines from the reservoir enough to loosen at least one of them. I ended up draining the reservoir and removing the inner chamber (clutch) in order to properly tighten the brake line from inside the reservoir. Then I reassembled the clutch chamber and tightened it. Leak stopped, but it was a little bi of a hassle.
vette
Hi Randy, I fill mine to the top of the inner cannister rim. Never had any trouble with spill over or slopping out. (Knock on Wood).
Randy Harris
Randy Harris
shorn said:
After replacing both my brake and clutch MC's, I found that my reservoir was also leaking onto my freshly painted engine bay. It took awhile to determine that the leak was from the bottom of the reservoir by the connection for the line to the brake MC. Apparently in removing the MC's....snip
Nope, it's definitely leaking from either the vent hole or it's coming up and over the threads of the cap. I'm betting the vent hole as there's freshly bubbled paint in the outer lip of the cap. I'm going to remove some of the fluid and see if that does the trick. Thanks guys.
Randy
shorn
OK Randy,
If it is leaking out of the top, you might purchase a new rubber gasket for the lid. Most auto stores carry one that will work, part # 42072. This rubber gasket has a microscopic slit in the top, which some of us have sealed (I did not). The slit is almost invisible (at least to 60 year old eyes), but look under a bright light. With a new rubber gasket, the reservoir should not leak either through the vent hole or around the threads.
I fill mine so that it is slightly above the inner clutch cylinder.
Dave Richards
I concur with Shorn, if you're sure it's not leaking from the connections at the bottom, it's the gasket. (The fluid's getting pushed around by pedal action.)
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
A brake fluid canister Austin Healey 4
H Which Part of the Brake Fluid Canister for Clutch? Austin Healey 8
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
