Hello everyone. I hope everyone is starting to get their cars out on the road with the better temps. Well. I have a few questions that I would like some feedback on.
1.) On my 78 Midget 1500, the center of the windshield has a threaded rod that I think acts as a support brace that runs to the rearview mirror. I want to take my mirror off to paint up the bracket and that rod as they are on the ugly side from age. Will this create problems removing this temporarly?
2.) I have this really anoying screaching sound from the engine bay. Its like finger nails on the chalk board. I found it to be the cover on top of the radiator. There is 2 bolts mounting it and the one is rubbing the top of the radiator and making the noise. When I look in the Moss / Victoria British catalogs there isnt even a bolt on that side in the pictures. Im wondering if I can just remove it but then the shield will be held with just one bolt? Its purpose is to protect you from the fan from above.
3.) On the differential, what can you use to open the filler cap. I finally checked and filled my tranny but I know the differential needs some fluid as well. Is there a square tool you can buy or do I need to grind down an extension socket or something?
Any info I appreciate.
Thanks gang.
Thanks gang.
