Missing at full temp
jbowlby
Im trying to diagnose why at full temp my 73 Midget 1275 is missing. New petronix and coil, freshly rebuilt carbs. no vacuum leaks.
I have noticed the coil is HOT to the touch after running. Could this be a sign of a faulty coil. I was under the impression a coil would either work or not.
Thanks!
Jim_Gruber
You might have a coil that requires a ballast resitor. These types use a higher voltage to start and then run at a lower voltage. I had that issue with a Mercruiser and went through 5 coils before I found out from sources other than the extras from the movie Deliverance that were holding my boat captive. Idiots, idiots, I was surrounded by idiots. And while the coil was working boat ran like a scalded cat. Then progressed into missing, missing, missiung runing worse and worse and finally quit.
And yes if coil is runing at too high a voltage it will get extremely hot and burn up.
I do not think a coil would cause a miss. It could be a bad rotor button and/or cap ... or plug wires.
I replaced my rotor button and cap with a unit from Jeff of advanceddistributors and my idle smoothed out quite a bit.
OK, I'm apparently wrong.
The thing to do would be to check the resistance of both the low and high tension of the coil while it is hot and see if there is a short.
jbowlby
jbowlby
Wish me luck, im heading to the garage with a large glass of ice water. I will switch the coil out with the old one. I dont know about you guy's but it's a tempid 97 here in Memphis today!
jbowlby
jbowlby
It's fixed! While I was switching out the coil I noticed a small black line in the coil wire. It had arched out and was causing the misfireing at full temp.
I guess a good rule to follow is when your stumped don't forget to check the obvious! I will add that the wire set was less than 1 year old and had less than 500 miles on them.
Thanks to everyone for your help!
jlaird
Well done. Always nice to find a cheep fix.
May I suggest that when you have a miss or interment miss you check the engine running in the dark.
mrsprite
Same thing happened on my nearly new set of plug wires. I had a very small rip in the boot and it arced and sparked (and missed) like crazy......drove me nuts figuring it out because how could a 3 month old set of $80 plug wires possibly be bad?
Anyway, glad you found the problem and that it's an easy fix.
tweety
so it was missing at IDLE when warm? Did you even try to drive it? If so what did it do.
Congrats BTW, there's nothing better than a simple fix for a problem that caused much mental agony
Jim_Gruber
With these cars it's usually something simple. We always go for the catostropic solution when often just plain old wear and tear or a loose connection.
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
F Missing and hesitation, only after a hot start Austin Healey 6
