bobh
I know this was discussed recently, but I thought this would be useful.
I wanted to change my transmission oil while I have the car on jackstands for a brake upgrade.
After reading recent posts about problems I wanted to make it as simple as possible. I have a set of 8 point sockets so the removal of the filler plug was easy. Don't even bother with any other tool. The 8 Point is the correct tool.
In one post someone mentioned the Sta Lube pump from Harbor Freight. This pump wouldn't screw onto my bottles of Redline MT90. So I bought the Harbor Freight Transfer Pump.
https://www.harborfreight.com/multi-use-transfer-pump-66418.html
I'm not a big fan of Harbor Freight tools, but this was on sale for $5.99 so it was worth a try. It worked quite well. There are a couiple minor things to mention. You should trim the orange tubing to the length you need to do this job. I used the full length and it's a little cumberson. Once the fluid was flowing I pumped a little too fast. That forced the lower hose (Output) out of the pump and sprayed oil all over my leg and the driveway. Take it slow and you won't have a problem.
The whole process took about 5 minutes. If you don't already have the car elevated add 5 more minutes to drive it onto ramps.
You should be able to use the pump in reverse to suck the oil out of your differential filler plug. Then use it to refill the diff.
At $5.99 it's almost disposible if you don't want to clean it for storage. Yesterday HB had a coupon in the paper $3.99 for the pump. That's a bargain worth buying.
BOBH
BOBH
