Spitfire Current Leakage, 1978 Spitfire
Joe_Pinehill
My battery is tending to die over 4 or 5 day of not using the car. I checked the current from the negative cable to the negative battery terminal when disconnected, and the car off, and I get 9 mAmps of current. I know its old car, and bound to be some leakage. Is 9 milli Amps typical? Wondering if I have a bad battery or have to hunt the source of the leaking current.
I was going to leave the negative off, and see how much charge it holds over night. Its a relatively new battery, less than 2 years old.
There just isnt that much wiring on the unswitched electrical bus wondering if it maybe the key switch. I dont have a radio.
martx-5
Nine mAmps is not a lot. It's typical of modern cars to draw between 10-20 mAmps. That shouldn't kill a battery for at least several weeks or longer. There shouldn't be anything drawing on your car, especially if you have no radio with a memory. Try disconnecting the big lead from the battery on the alternator and see if the draw goes away. Sometimes the diodes will leak, but I'm still not convinced that should be enough to kill the battery after 4-5 days. The proof would be to disconnect the battery and see if it still goes flat. That would indicate a bum battery.
TR3driver
Great Pumpkin - R.I.P
If only 9ma is killing the battery in 4 or 5 days, then IMO the battery is seriously weak and should be replaced. That's only about 1 amp-hour, and your battery should be good for at least 40 ah (especially at such a low rate).
As Art says, it could also be the battery self-discharging, which would also mean a new battery.
Another thing to check, perhaps, would be that the battery is getting fully charged in the first place. A bad connection or a wonky voltage regulator might be putting barely enough into the battery to start a warm engine once.
But I've also seen several cases where the leakage varied over time, measured quite low but became higher under some circumstances. My motorhome had that problem; turned out to be mud caked around a solenoid terminal that would become much more conductive when moist from dew or rain.
Most severe case I ever saw was my 1970 Audi, where the relay for the rear window defogger would pull in when it got damp! Never would have solved that one, if I hadn't happened to walk by the car one night and seen the indicator lamp glowing on the dash! Probably, the phenolic relay base had just gotten contaminated with salt and dirt, but I replaced it anyway.
Twosheds
Look for a puddle of electrons under the car, then follow the electron trail to the leak.
Platinum
John's solution has my vote. Just be sure to check that they're actually genuine Lucas Positive Earth electrons an' not an earlier spill from some domestic system. :smirk:
<span style="font-style: italic">EDIT: Go with Art 'n Randall's suggestion, tho. Seriously, sounds like that battery is FUBAR.</span>
Don_R
Doc,
Its a 78 Spit. It shouldn't spill positive earth electrons. The car is Neg earth. It would be very hard to seperate these electrons from a domestic source.
Platinum
eep! Neglected t' notice which year Spit! mybad.
Y'd have to pass a sampling of th' spilt suspect 'trons thru a Lucas smoke capacitor then.
Too much argie, wot wif exchange rates, shippin', VAT an' all.... Jus' replace th' battery. :devilgrin:
Platinum
...Joe's gonna hate us....
71MKIV
What's the voltage reading first thing in the morning after running the car the day before.
anything less than about 12.5 vdc, your battery has issues.
This will sound stupid, but I've had it work for me. Take it out of the car, and bounce it on the ground a couple of times, and slosh it back and forth. sometimes that will shake the lead sulfate out of the plates enough to buy you some time.
Platinum
...ummm.... I wouldn't do that.
TR3driver
I'd certainly be VEERY careful with the "bouncing" part. Those things are surprisingly fragile, and you probably won't enjoy the bath in sulfuric acid.
And just a spirited drive around the block should give it about all the "sloshing" it can stand
71MKIV
What kills the batteries in our little cars is the lead sulphate flaking off the plates and building up in the bottom of the batteries until it shorts the plates. The longer the warrenty of your battery, the deeper the sump is at the bottom of the battery.
I agree that the term "bouncing" connotates something a little harsher than what I had in mind. tapping maybe?
a small discharge, described here, might be dealt with by tapping and rocking the battery back and forth, and save the owner the expense of purchasing a new battery.
And no, driving the cars does not rock the battery enough to accomplish that.
I am assuming here that the owner of the car is very fussy about the appearance of his car, and keeps the top of his batter very clean in keeping with the rest of his car.
TR3driver
All a matter of how you drive, I suppose :devilgrin:
And FWIW, I don't think I've ever had a battery fail that way in a TR. It has happened, sometimes, in the family "grocery getter". But even there, usually the batteries just lose too much capacity, rather than developing a shorted cell.
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
C Current Austin-Healey Market Values Austin Healey 18
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
T General Tech Current draw - various accessories Triumph 9
simon1966 Current day grease choices? Austin Healey 3
T TR2/3/3A Starter current/Bently Triumph 4
A Current drain Jaguar 6
E Austin Healey current pricing of cars Austin Healey 20
T current instrument rebuilding info from Nissonger Austin Healey 3
PC current events Spotted 9
V Current draw problem??? Spridgets 16
B Current BMW restoration Other Cars 6
Stinger TR4/4A Current TR4A Demand Triumph 7
tweety More on the current draw issue... alternator Spridgets 2
tweety Current deaw.... draining battery Spridgets 3
B Correct oil for TR's given current zinc issues.... Triumph 18
Starbuck My first posting and current restoration pics MG 8
R color of hot wires, more current draw questions-BJ Austin Healey 7
S Current Restoration of BJ8 Austin Healey 0
AweMan If I only had 3 phaze current in my garage Restoration & Tools 2
timbn2 nice BN2 on ebay...current bid 55K Austin Healey 2
H Current Values of a Bond Equipe 4S? Triumph 1
jlaird Current status/14 May 2006 Spridgets 0
F Wedge Background on my 1980 TR7 & current Idle problem Triumph 3
trboost Current issue of British motoring Triumph 3
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T How much dashpot oil leakage is normal Triumph 14
dklawson Spitfire Water Leakage Paths - Spitfire Triumph 16
B Fuel leakage at carby on V12 Jaguar 4
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
