TR2/3/3A Headlights and their extreme current draw?
karls59tr
Bronze
I have an alternator in my 3 so I installed a voltmeter. It seems to me that the headlights sure draw a lot of current when in use.Is this normal? If I was to have the heater on at the same time would that not be a lot of drain on the battery? Is there an upgrade to the charging system?
Hamish Racing
You can go for a bigger alternator Karl. My UK perspective-
The original dynamo put out about 22amps. A lot of the alternators used as alternatives are 40amp
I use a small 40amp denso / kuboto type and it seems to cope. I have changed the heater to a modern version after the original leaked.
you can just get a bigger capacity alternator say a 55amp.
or if you are allowed there are some very good LED headlight set ups available which considerably reduces the current required.
Sarastro
First, a pair of headlights will pull approximately 10 amps. That's not a huge current, by automotive standards. Are you seeing more than that?
Second, an alternator should handle that current easily, even at idle. It may not be connected right.
CJD
Some numbers:
Headlights: 10 amps
Tail lights: 4 amps total
Brake lights: 2 amps
Heater: 5 amps
Ignition: 1 amp
Dash slights: 2 amps
Windscreen wipers: 5 amps
Total with everything that a stock car has to run, running: 29 amps
Dynamo output: 19-21 amps
So, as you can see, if you are in the rain, in the winter, at night, you are on a limited time before your battery runs down! Even adding a radio in fair weather is maxing out the stock generator system. On the other hand, a 40 amp alternator will have no trouble at all powering a stock car plus a little extra.
RJS
I installed a pair of LED H4 bulbs from ClassicCarLEDs in the UK. Warm white color (3000*K, look period correct, not that super white/blue of modern cars). Waaaay more light output and only uses 3.2amp/pair vs 10-12 amps for halogen bulbs
Bob
W TR6 Headlights Triumph 5
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B TR4/4A Headlights Blink Off Triumph 15
7 polishing headlights Restoration & Tools 5
K 68 midget. No horn, headlights, turn signals Spridgets 9
Rob Glasgow Halogen Headlights Austin Healey 30
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
B TR6 LED Headlights Thouights? Triumph 14
T Ignition warning light remains on and headlights come on Austin Healey 8
JPSmit Green Mini - with halo headlights Spotted 0
P TR6 New headlights Triumph 24
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
R TR2/3/3A Sealed-beam headlights Triumph 15
R Sealed-beam headlights Austin Healey 13
KVH TR4/4A No Headlights Triumph 4
S TR2/3/3A little caged nut headlights Triumph 2
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
P Porsche with 5 headlights Other Cars 5
Scotsman TR2/3/3A LED headlights Triumph 4
C TR2/3/3A How to wire headlights for TR3 Triumph 5
AUSMHLY LED headlights Austin Healey 36
rjc157 headlights Austin Healey 12
turbofrog Sprite Control Box - Headlights In-Op Spridgets 4
P Headlights and Turn Signal Light Grounding Spridgets 3
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
T TR2/3/3A TR3 headlights Triumph 12
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
D BN2 headlights Austin Healey 3
RickB Lucas Headlights - Just got this from VB Spridgets 8
N Headlights?? Spridgets 8
I Suggestions for bugeye headlights Spridgets 21
F Headlights Stopped Working TVR 2
B Adjust headlights/ "true" them? MG 7
A TR2/3/3A TR-3A Headlights Main versess Dip Triumph 10
Nelson No more forgotten headlights Spridgets 2
PATR8 Wedge TR 8 headlights problem Triumph 11
AngliaGT New Elise Headlights Anyone? Lotus 2
N Adjusting headlights on a BJ8 Austin Healey 2
H Headlights left ON reminder MG 3
Nelson Aiming headlights Spridgets 1
Trevor Jessie Headlights Spridgets 34
M Headlights and fog driving lights Triumph 44
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
B HID Headlights? Spridgets 4
mountainman TR2/3/3A TR3 Headlights Install? Triumph 6
S Headlights Triumph 32
