TR6 LED Headlights Thouights?
bunzil
While I am sure it's been covered, a quick search didn't uncover what I was looking for. Simply, does anyone have LED headlights installed and, if so, your general impressions? I know all the benefits, just looking for some feedback. I think almost as important as the added light is the relief on my headlight switch on my TR6. Many thanks.
Gliderman8
+1 on adding a relay to do the switching. I don't have LED headlights but I did switch to halogen headlights and they are far superior to the stock incandescent ones.
Geo Hahn
I guess TR6's don't have a headlamp relay? TR4s didn't and I added a pair to eliminate the tendency for the switch to double as a hand warmer. Later I went with LEDs.
One big advantage to the LED headlamps - I usually drive with the headlights on in the daytime and the draw is so small (about the same as a brake light) that the generator can keep up.
B
bunzil
Re: LED Headlights Thoughts?
No, the 6 didn't come with a headlight relay which, of course, is part of the desirability of LED's because the load drops from about 5 amps to just over 1. This would be a welcome gift for the switch. I can easily add a relay but try to resist making such mods unless absolutely necessary. I suppose my main question is; how did you find the cosmetic switch going from the warm glow of period correct incandescents to the stark white of LEDs? Thanks.
poolboy
"How did you find the cosmetic switch going from the warm glow of period correct incandescents to the stark white of LEDs ? " ?
I didn't find it offensive, if that's what you mean.
pdplot
One of my original headlights burned out and I replaced both of them with halogens. Straightforward job except for those %^&*# headlight rims. One was easy. The other one took me 20 minutes of cursing before it finally hooked on. You nay think you have it but hit a bump and the rim flies off. Stick with the ones with the screw on the bottom.
poolboy
Been there.....And those rims aren't cheap either.....
Madflyer
Have you changed out the dash lights from 3W to LED. Much better a night Taking out the Tac get to them pretty well. Madflyer
B
bunzil
Did you have an issue with the dimmer or bypass same?
Madflyer
Yes I remover dimmer all together. My TR 6 1973 key switch under steering wheel went bad so I removed it also and replaced ign. switch in that space in dash parts from Summit. Locking steering wheel junk any way. If I could post pic on Thread would show same I am still new here. Madflyer
B
bunzil
Thanks. I know we're off the headlight topic now but one last question; where did you find the LED dash replacements?
carpecursusII
A company called Litezupp has everything you need. Bulbs are drop in replacement and it means you get to keep the original switch. If you change the blinker bulbs to LED you need a different flasher which they have. I have bulbs from this company in my cars along with the rest of my club. The owners are LBC people, one owns and drives a 3 and a 250, they understand the cars and what they need.
www.litezupp.com
Geo Hahn
... I suppose my main question is; how did you find the cosmetic switch going from the warm glow of period correct incandescents to the stark white of LEDs? Thanks.
For me that is a drawback. The main use of my headlamps are daytime driving (long 2-lane highways in the desert) and the white of the LEDs is harder for oncoming drivers to pick up than the yellowish look of incandescents. Still, I'll stick with the LEDs for the other advantages.
B
bunzil
Thanks. The information is appreciated.
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
Scotsman TR2/3/3A LED headlights Triumph 4
AUSMHLY LED headlights Austin Healey 36
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
