TR6 LED Dash Lights
gbtr6
I am planning to change over my lights to LED for the gauges. Are all the light bulbs for illumination screw base or bayonet? I have a 74 and cannot remember. The other thing is how hard it is to reach some of them.
Thanks,
Perry
gbtr6
gbtr6
Is there no one out there that know for sure if the bulbs for gauge illumination are screw type or bayonet type? No one has done the LED conversion? Or replaced their bulbs?
Perry
poolboy
Perry
According to the Moss catalog there are 12 that screw in, the others are not; maybe you can look in the TRF Green catalog Plate EN and count them up.
gbtr6
gbtr6
Thanks for the replies. I appreciate the info.
Perry
glemon
I am not sure about a 74, but for my 68 Triumph and most British sports cars of that era you are looking for an e10 screw base, 12v of course, Google search or eBay or Amazon will turn up many options. Bulb head will need to be similar size to your current bulbs, bigger ones won't fit.
gbtr6
gbtr6
Thanks, I have some coming from china, they were not too expensive, so I'll post what I get and how they work. I imagine it's pretty tough to reach the small gauges, even after removing the radio and center support.
Perry
glemon
Yes, the top center of the dash is it can be done, but access is pretty limited up there, you probably have a few more wires and connectors to work around, kind of trade off between how much you remove to gain easier access.
matttnz
Member
Just had the dash out on my CR '74. They're all screw base, 2.2W 12V.
Much easier to remove the kidney pads & heater hoses.
Marla TR4/4A Led dash lights Triumph 0
P LED Dash Lights Spridgets 1
hondo402000 LED Dash lights Triumph 15
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
K TR2/3/3A LED dash bulbs again? Triumph 2
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
S LED Dash Bulbs Spridgets 10
Boggsy64 MGB LED dash bulbs MG 3
B Dash Light Replacement [not with LED] Austin Healey 6
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 14
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
D TR2/3/3A TR3 LED Lights? Triumph 5
