Correct oil for TR's given current zinc issues....
bunzil
I am certain this has been covered but I could not find the posts in my search. What is the general feeling these days on the correct engine oil for pre-catalyst TR's? All of the oil producers have been forced to significantly reduce essential lubricants needed by many older flat tappet engines to meet with more demanding catalyst warantee requirements. This applies to many of the oils recommended for our motors 30 years ago - including Castrol GTX.
Two solutions seem at hand, perhaps there are others:
1) use Castrol Syntec 20-50 made solely for the needs of these older engines
2) use an additive such as ZDDP which replaces the needed zinc and other lubricants needed by our engines.
What is the current feeling on this issue?
Thanks.
TR3driver
Great Pumpkin - R.I.P
A large and thorny topic, Ned, much more complicated than your summary would make it seem. Personally, I've been using Valvoline full synthetic 20W50 for many years, and see no reason to change.
Brosky
I used Shell Rotella Triple T (Diesel with ZDDP) for break-in and a few changes after, per machine shop recommendations. I have a case of Classic oil from Moss to use up after and a case of Castrol Syntec 20/50 for flat tappets as you mentioned above. It's a toss up as to which one I'll go to after this oil is changed later in the summer.
Brad Penn is another well recommended oil for these. If you like green oil....
Brosky
See? I told ya!!
I grew up in western PA, so I like the oil from that area.
AngliaGT
i've been running Castrol 20-50 in the TR6,
but switched to Valvoline VR1 Racing 20-50.It's a
little more expensive,but I don't put that many
miles on it.And besides,it's not hard to find.
- Doug
M_Pied_Lourd
VR1 20/50 as well.
Cheers,
M. Pied Lourd
RJS
Well, 10 years with my TR4A following a rebuild I used a diesel spec Pennzoil 15W/40 for a long time which has high levels of zinc as well as very high levels of detergents.
I have recently moved over plain old Castrol GTX 20W/50 with ZDDPlus additive.
Two observations from all of my reading and research on this subject:
1) Zinc levels are most important on initial break-in for sure. However, the benefits of high zinc levels are still not as clear after that break-in. However, the conservative in me continues to supplement the zinc levels
2) the zinc is sacrificial in nature meaning you only really need high zinc levels if you are running long intervals on your oil changes. For someone like me who drives ~1000 miles per year and changes the oil at the end of each season, it's probably a non-issue. But again, the conservative in me supplements my zinc levels with ZDDPlus.
Bob
DougF
It was explained to me last year by a Brad Penn distributor that many of the 15w-40 Diesel Oils would be losing their ZDDP over time. Make sure to check your labels at purchase. Unless specified, all road going oils were to be losing ZDDP.
Racing Oils are generally safe since they aren't sold for on road vehicles. I use Brad Penn 20w-50 Racing "Green" Oil as mentioned earlier. For start up on my new engine, I will be using Brad Penn 30w Break In Oil.
dklawson
I don't often chime in on ZDDP threads because there is no consensus and even the studies out there can point at conflicting conclusions.
That said, for my British cars I use Castrol GTX 20W50... and then I add... STP-Red. Yes, STP, the snake oil from our childhood. Forgetting all the bad press about the company and all the company's self promotional hype, the factory states that their products do include high levels of ZDDP. It's a fraction of the cost of additives marketed exclusively as ZDDP replacements and it is available almost everywhere.
We use Brad Penn in the Formula-Vee but as stated above it costs more. If you don't want to use STP or the other additives you will not be disappointed with Brad Penn.
Andrew Mace
I bought my current Herald driver in 2002 with 50,000 original miles on it. Best I know, the engine had never been touched, and it hasn't since I've owned it. I've put over 30,000 miles on it in the last seven years. All I've ever used is Castrol GTX 20w/50 (sometimes a lighter weight in late fall or early spring). In the last several years, I've used the "High Mileage" version of GTX.
Given that the willing little 40 hp 1147 has to work pretty hard in today's traffic compared to even most other Triumphs, nonetheless I've yet to see anything approaching a problem with flat tappets from lack of ZDDP, nor have I seen any trace of valve seat recession from lack of lead in the gasoline.
Maybe I'm lucky...maybe I'm due. Maybe there's a bit of "hype" out there.... :smile:
Andrew Mace
TR3driver
Or a lot!
:devilgrin:
B
bunzil
Great responses - thanks. This is one that could have quietly slipped beneath the radar but it seems everyone has been following the topic.
How were we to find out that producers have significantly reduced the zinc from all oils specified for new unleaded fuel cars to comply with the Fed's demanding 150,000 mile catalyst life? Even the trusty oils from just a few years back - like GTX - have been reformulated. Here I always thought oils were constantly improving, but in light of this discussion, and perhaps the unique needs of older cars, the word "improving" is questionable.
Thanks again for the input - and speedy response.
TR3driver
As usual, it depends on your definition of "improved". If your goal is to reduce emissions, and fuel consumption; then getting old cars off the road is an "improvement".
DaveatMoon
ZDDP concentrations in motor oil have been reduced in the latest SM classification from a previous maximum of 0.14% to a current standard of less than 0.08%, with most SM oils between 0.06 and 0.08% although some are lower. That's a reduction on the order of 50%.
There are likely to be further reductions in ZDDP in the coming years, however, and this teapot tempest may be an issue in future. ZDDP concentrations in the SM range (0.06-0.08%) are adequate to protect cam wear in engines with valve lifter pressures of roughly less than 475 lbs., which are not exceeded by very many stock motors (<span style="font-style: italic">for instance my TR6's valves operate at roughly a little less than 200 lbs</span>). The current situation is probably much ado about nothing for all but a very few engines among stock vehicles. High performance/modified engines are another matter entirely. This can be seen by reading between the lines in even the very promotional literature used for ZDDP additive products, for instance see: ZDDP and Cam Wear, Just Another Engine Myth?.
ZDDP concentrations higher than 0.2% actually attack the metallurgical makeup of iron in camshafts, causing camshaft spalling. So too much ZDDP is actually <span style="font-weight: bold">much worse</span> than not enough. Using these additives can be a risky form of roulette, like many "snake oils".
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
K TR2/3/3A Correct oil level for differential? Triumph 5
BN6_2197 Question on correct oil temperature Austin Healey 15
R bj7 correct oil Austin Healey 5
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
I Which oil filter canister is correct? Spridgets 3
R correct rear axle oil Austin Healey 1
chicken BJ7 correct oil pressure Austin Healey 38
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
